V6 AEM Standalone Question
So I'm working on a custom setup and trying to keep cost down. There is no standalone available for it that is specific. A friend has two AEM standalones, one is for a 4-cylinder universal and the other is for the J-series V6. I have a V6 so I figured the J-series one would work best for me. My questions are:
-Can I use an engine specific standalone on any other engine (same amount of cylinders), if I rewire the harness to match up? It seems like it's just all the basic sensors and outputs that it needs (MAP, TPS, Injectors, etc...). I assume I would have to make a basemap from scratch.
-Do the 4-cylinder universal ones only have four injector drivers, so it wouldn't be possible to use on a V6?
Any help is very much appreciated.
The 30-1040 only has 5 coil drivers. If your motor is a distributed V6 than this shouldn't be a problem. There are some limitation on the 30-1040 since it is a Version 1. The best bet would be to go with the J-Series one. This can be converted to run pretty much anything.
The 30-1040 has 10 injector outputs. However you will be required to use the old software AEMpro. AEMTuner is the newer software. Also hardware wise the J-Series is a much better ECU.
