engine is reving wrong
Old Jan 22, 2014 | 05:10 PM
LandeZak's Avatar
Default engine is reving wrong
I recently got my engine tuned by my neighbor. He changed my ECU for his in his integra and now my engine is reving weird. If i start pushing the gas down and its under 3000 RPMs, the car wont move very fast, but once it reaches 3000 it starts going fast. Any ideas on how i can fix it? He said to get it dynoed but I'm not sure
Old Jan 22, 2014 | 09:20 PM
B_Swapped93's Avatar
Default Re: engine is reving wrong
lol how did he "tune it" I hope to god he didn't just give you his teg ecu and say done. What engine/mods what ecu did you have before this and what ecu do you have now. and if he said get it dyno's that's NOT getting it tuned he just stole your ECU lmao.
Old Jan 22, 2014 | 09:40 PM
NotARaCist's Avatar
I never narc'd on nobody!
Is your neighbor a kid called Hazma?
What engine do you have in your car? What wiring harness? What ECU (specifically) did your neighbor put in the car? Do you have any mods? Is your CEL on? Does it work? There is entirely too much information missing for us to tell you what's going on here.
Old Jan 22, 2014 | 10:02 PM
LandeZak's Avatar
Okay I'm not a huge car guy but i trust the guy who did it. He used to race the integra and did pretty good. But I needed a timing belt replace and he was showing me how to do it. But once it was done the car was not running correctly so he said he would try and fix it and it took like a week to get it fixed. We had to replace a ton of stuff like my alternator and he redid a lot of the wiring. But he was just seeing if the new ECU would work and he just took it from his integra. But since it was taking so long he just told me i could keep the ECU and he would buy a new one for his Integra
Old Jan 22, 2014 | 10:05 PM
LandeZak's Avatar
I have no mods. I have a '01 Integra B-series. I do not know the ECU. i think its a P-something. and my CEL isn't on.
Old Jan 22, 2014 | 10:56 PM
NotARaCist's Avatar
Oh boy, this is probably going to be an entertaining clusterfuck. Look at the ECU, figure out what the code is, and also post a picture of the plugs. If this all started after a timing belt replacement, then the replacement was done incorrectly - that has absolutely nothing to do with the ECU. You need to invest in a timing light.
Old Jan 22, 2014 | 11:22 PM
lol.
op 01 integra b-series so what an lsv gsr b18b1 cmon....as for the ECU p72 p75 ?
Old Jan 23, 2014 | 10:05 PM
LandeZak's Avatar
i know man ****. but i will send a picture asap
Old Jan 23, 2014 | 10:06 PM
LandeZak's Avatar
Originally Posted by B_Swapped93
lol.
p75 that was it
Old Jan 23, 2014 | 10:09 PM
LandeZak's Avatar
well the guy said that the way it revs is made for autocross which is what he did. But would the ECU not affect that?
Old Jan 23, 2014 | 10:12 PM
NotARaCist's Avatar
"The guy" is a ******* idiot. Stop letting him work on your car. Stop letting him sit in your car. Stop letting him even LOOK at your car.
Post a picture of the plugs going into the ECU. We can try to work from there.
Old Jan 23, 2014 | 10:14 PM
find stock(virgin) P75 ECU and use that, that's a horrible excuse for auto x you want low down tq as most of the time you're going under 40mph around cones. I don't even do auto x and i know that. no chipped ecu would have it bog under 3k then come on like a turbo after 3k.
Old Jan 23, 2014 | 10:33 PM
LandeZak's Avatar
I will tomorrow. its 11:30 pm here. thank you though!
LandeZak's Avatar
okay. thank you!
Old Jan 23, 2014 | 10:45 PM
NotARaCist's Avatar
More specifically, you should use a P75 ECU that matches the OBD variant of your car. If you have a 96-98 Civic, you want an OBD2A P75. If you have a 99-00 Civic, you want an OBD2B P75.
Old Jan 24, 2014 | 09:36 PM
LandeZak's Avatar
i have a 99 civic but its swapped for an 01 integra engine. so which ECU would i get then?
Old Jan 24, 2014 | 09:58 PM
JoeBlue's Avatar
OBD2b.
Old Jan 24, 2014 | 10:08 PM
LandeZak's Avatar
thanks
Old Jan 24, 2014 | 10:28 PM
NotARaCist's Avatar
Originally Posted by JoeBlue
OBD2b.
Yep, match the ECU variant to the chassis harness used.
Old Jan 24, 2014 | 11:39 PM
tony_2018's Avatar
Fish Twig
Actually.......if he uses an obd2b integra ecu he will run into issues with the immobilizer. COME ON GUYS YOU SHOULD KNOW BETTER.
Old Jan 24, 2014 | 11:43 PM
NotARaCist's Avatar
Except immobilizers are easily removed, and you can't just plug and OBD2A ECU into an OBD2B harness.
Old Jan 24, 2014 | 11:46 PM
tony_2018's Avatar
Fish Twig
If you noticed, he allowed someone else to work on his car...doesn't sound qualified to modify the immobilizer chip. Its better to get the obd2a and get the conversion harness.
Old Jan 25, 2014 | 02:17 AM
HondaPartsHero's Avatar
Technical Hero
This^
Old Jan 25, 2014 | 02:35 AM
NotARaCist's Avatar
And there are a number of professionals out there that can remove immobilizers for cheap.
Old Jan 25, 2014 | 03:37 AM
Technical Hero
http://b16a2.kicks-***.net/automotiv...mmo-remove.htm
EG-6SRNAC
14
May 12, 2010 11:59 PM
ir0nmanx
Jan 20, 2008 09:07 AM
agiorlando
May 18, 2007 11:31 AM
89civichatchback
Jan 18, 2003 07:58 AM
