97 Gsr Tailight and interior Light issue
Old Jan 21, 2014 | 07:22 AM
vtecwreck's Avatar
Default 97 Gsr Tailight and interior Light issue
Whats going on HT? I recently purchased a 97 Gsr.(Due to some advice from Tight-r). So the guy who owned it before me had a mess of cables and wires due to having a "massive System" in the car. Also along with those wires he did a lot of BS "Hard Wiring". So a problem I'm having is that the tail lights and instrument cluster lights don't turn on when i turn on my running lights. He has a cable running from the fuse box which is connected to one tooth of a 10v fuse and there is another cable connected to the other tooth and that cable goes all the way to the trunk and is somewhat rigged into the tail lights. Connected to the cable which is running to the trunk are two more cables... a Blue one and a Red one, he connected them together to get the running lights to work and disconnected them to shut the lights off... I Had the same problem before on my previous 94 ls... and it kept burning through fuses, but i just kept putting in new fuses and then it finally just started working... I will post pictures up Tonight.
Old Jan 21, 2014 | 07:39 PM
vtecwreck's Avatar
Bump
Old Jan 21, 2014 | 08:49 PM
collkid's Avatar
Default Re: 97 Gsr Tailight and interior Light issue
Yeah if you throw pictures it might help. But I would start by pulling out anything that isn't stock. And obviously check fuses.
Old Jan 22, 2014 | 08:12 AM
vtecwreck's Avatar
Here are the pictures. I removed almost all the cables except the light one since I daily drive the car
Old Jan 23, 2014 | 12:28 PM
97Lsdc4's Avatar
yup what he said^^ take out all the wires that aren't stock and from there you will probaly find out the problem,check fuses also i had a problem on my ls where dome light wouldn't work,so i replaced a fuse and it works fine now!
Old Jan 24, 2014 | 04:11 AM
vtecwreck's Avatar
I did manage to take most of them off... and my cluster did light up. Theres only a few more under the dash. Also I heard that if one of the bulbs are blown then they dont turn on? I will be changing the bulb today regardless but just wondering if that was true. Thanks again
Old Jan 24, 2014 | 06:50 AM
fcm's Avatar
fcm
Old Fart
No. 94
Old Feb 18, 2014 | 07:33 AM
vtecwreck's Avatar
Still haven't had the chance to work on the light issue, but currently my turning signals went. I changed the fuse on the underdash fuse panel but only my hazards began working again. Any ideas what this could be?
Old Feb 18, 2014 | 04:45 PM
fcm's Avatar
fcm
Old Fart
Fuse #26 is for the signal lights, [under dash fuse box].
Fuse #43 is for the hazard lights, [engine bay fuse box].
If the hazard lights work, all blubs/wiring/flasher are good and problem with signal lights is before the hazards switch or the switch itself, pull switch and test the yellow/black lead for power when ign. switch is on, if you have power, replace the switch, if no power check for power at the fuse with ign. on, [fuse #26], if no power, replace the fuse box, if there is power find "open" between the fuse box and the hazard switch.
Because there was an aftermarket stereo, chack and make sure the red/black,at the stock radio wire harness, is not shorting or connected to anything, fuse #19 is for the park lights and instrument lights, test for power ar the fuse. 94
Old Feb 18, 2014 | 07:17 PM
GagnarTheUnruly's Avatar
If you need an OEM harness I have a 96 car harness that should be compatible.
Old Feb 18, 2014 | 08:58 PM
vtecwreck's Avatar
Cool thanks ill check everything out tomorrow. Any clue what could be wrong with the running lights?
Jason7872
Honda Accord (2013 - 2015)
Mar 31, 2019 10:45 AM
sweux
Aug 5, 2017 06:02 AM
LogsTeggy
Mar 29, 2015 04:13 PM
alfaaay
Nov 10, 2009 05:30 PM
slammeddelsol95
Dec 30, 2004 07:46 AM
