My ported GSR head flows 261 & 189 @ 28"
Old Jan 15, 2014 | 06:13 PM
blue1gen's Avatar
Default My ported GSR head flows 261 & 189 @ 28"
Seems like it could be better. How does this compare on the scale of good flowing heads?
Old Jan 15, 2014 | 06:29 PM
Untengijutsu's Avatar
Default Re: My ported GSR head flows 261 & 189 @ 28"
what lift ?
B18CR head, Portflow job
At .500 and 28''
288.4CFM intake, 202.4CFM exhaust
Uncut guides
I trully like this head and the servies I got from Tom and Laskey Racing, it putted good power too, see sig.
Old Jan 15, 2014 | 08:06 PM
blue1gen's Avatar
.500", 288" & 202" is impressive. Was that with stock valves?
Old Jan 16, 2014 | 08:04 AM
slowsleeper's Avatar
Every flowbench reads a little different from one another even though they are/should be calibrated. Most "ported" heads flow around 280ish CFM intake though so take that for what its worth. If it can flow around there you'll be able to make good power from it. Obviously the shops with more experience and technology would be able to get more flow than 280 but 280 would be a decent flow number to base off of.
Old Jan 16, 2014 | 03:47 PM
Stock size, off the shelf supertech dished valves.
I wanted to keep the guide uncut, Mike at Laskey was also impressed by the number for this job.
Old Jan 17, 2014 | 01:12 PM
93egSLEEPER's Avatar
I posted in another thread but I have my head I hand ported flowing right at 290/205. It took ALOT of time and fine tuning, but it will be worth it when I finally get to slap it on.
Here is a pic
Old Jan 17, 2014 | 01:49 PM
blue1gen's Avatar
Really nice. I'm going to give them a hard time. I picked it up to check v2v clearances & when I take it back I'll say they can finish porting it now.
Old Jan 17, 2014 | 08:25 PM
1998GsRIntegra's Avatar
Was any work done to the chambers?
Old Jan 23, 2014 | 06:03 AM
J.Berta's Avatar
This is my gsr head before and after with stock valves.
Old Jan 23, 2014 | 06:06 AM
J.Berta's Avatar
Sorry for the pic being sideways. I don't understand why it rotated like that.
Old Jan 23, 2014 | 06:18 AM
Were you asking me or the OP?
JBerta that flow chart looks nice for a street head
Old Jan 23, 2014 | 11:49 AM
vtecmasta85's Avatar
Do you have a flow chart for the head? For instance a stock itr head usually flows around 260-265 stock depending on where it was tested at.. cfm is just capability really, the numbers in my opinion are just numbers if one doesnt have the support mods to use that cfm number. Your head might be a low/mid lift monster and you not even know it :-D.
carlosd68
Jan 2, 2013 05:28 AM
H-allmotorda9
17
Feb 6, 2010 07:40 PM
whatisJDM
Apr 8, 2007 12:27 PM
AlienKrOZ
Dec 23, 2006 11:13 AM
meanteg
Aug 30, 2003 03:54 PM
