Spun rod bearing ?
Happened recently havnt driving it since this happened can't figure out if rod bearing or anything with valves ? Any help will be good ! Thnx
edit video here
https://www.youtube.com/watch?v=Lnrj...ature=youtu.be
edit video here
^Actually got me laughing! But yeah, not enough info. I'd only say at this point is that if the noise itself is completely constant and increases/decreases with RPM that it may be more likely to be valve related.
sorry im trying to upload a video it didnt work thru iphone sorry
Sounds like a rod bearing
My engine sounded the same way not too long ago.
Also had a valve lash problem definitely not as loud af that knock.
Stop turning it on before you damage the piston further more and the crank
KooK
Dec 7, 2005 11:43 AM
