Suspension Bushing questions
Old Jan 13, 2014 | 06:50 PM
guy_from_nerk's Avatar
Default Suspension Bushing questions
Let me start by saying I have been searching all day and never really found an answer. I am wanting to replace the now 20 year old bushings in my Integra and have a few questions.
Which ones are the most important to change in terms of seeing a benefit at the track, front lca's, compliance, rear trailing arm?
What brands are there left? I spoke with Suja1 and they are discontinuing their bushings, haven't heard much from Hard Race lately and then there is Energy Suspension which seem to be the cheapest.
What sort of improvement will I see by replacing the bushings, if any?
Old Jan 13, 2014 | 06:57 PM
Turbo-LS's Avatar
Default Re: Suspension Bushing questions
Hardrace makes a complete kit for under 300 and this will improve suspension performance. Above that your looking at spherical bearing setups that's aren't that street friendly
Old Jan 13, 2014 | 07:01 PM
I know there is also Kingpin but I don't have the funds right now for their bushings.
Old Jan 14, 2014 | 03:34 AM
tepid1's Avatar
Originally Posted by Turbo-LS
Kingpin spherical bushings are really track only. There going to really stiffen up the suspension and throw ride quality out the window. If this is a street car stock with energy suspension or hardrace. If it's a track cwr then that's different story
That is completly incorrect. Have you ever been in a car with Kingpin wardware? My car rides smooth as hell. and I have 100% of my suspension done with Kingpin Machine.
Please don't put out bogus info.
Old Jan 14, 2014 | 04:24 AM
Turbo-LS's Avatar
I stand corrected and misinformed. Thank you for the correction Chris. Post deleted.
Old Jan 14, 2014 | 05:53 AM
sleepinonacreeper's Avatar
I've been using new oem bushings. I tried energys and wasn't happy with the wear in such a short time. To go with tepid said, I've never driven on kingpins but most newer upscale cars don't use bushings anymore. They all have mostly ball joints and some spherical and they ride great.
Old Jan 14, 2014 | 07:14 AM
h2.4's Avatar
Kingpins aren't going to make your car any stiffer, if anything it will make the stroke smoother. The only thing is, when street driving, it will not dampen shocks from the road to the chassis, because there is no flex. Which is the whole point in installing them in the first place. But it really isn't a big deal, I have sphericals on one of my cars, and it doesn't bother me a bit driving it on the street.
Old Jan 14, 2014 | 08:22 AM
PuroMotor's Avatar
I run the Hardrace kit on my car. Every single bushing from front to back. (you'll need a press and a lot of patience to install) You will notice a stiff ride right away. Bumps will feel very harsh but overall tolerable on the street. Just a tip, make sure and double make sure they send you the right RTA bushings and the middle rear lower control arm bushings. I along with others have been sent those two particular bushings incorrectly. I've been in a car with Kingpin products and its was a good ride as well, both will work, one is cheaper.
Old Jan 14, 2014 | 12:08 PM
Tuner Eddy's Avatar
The guys with spherical bushings no longer run traction bars, correct?
What about the guys with aftermarket bushings that are not spherical?
Old Jan 14, 2014 | 12:38 PM
PuroMotor's Avatar
I run traction bar with non spherical
Old Jan 14, 2014 | 04:24 PM
tepid1's Avatar
I run the Kingpin hardware and no traction bars. Best 60' to date is a 1.49
GagnarTheUnruly
Apr 19, 2020 03:55 PM
kicken90crxsi
Feb 8, 2011 03:32 PM
Historyg
10
Dec 17, 2007 01:01 PM
Severus
14
Jul 6, 2003 07:06 PM
scratchline20
10
Apr 30, 2003 09:00 PM
