strange idle problem
Well I'll start at the beginning. My 1996 civic lx, snapped the timing belt a few days ago while cruising at about 2800 rpm. Of course the valves smack pistons, valves bent pistons fine. I put a different head on it, from a 99 civic with the y7 with only 56k miles. Got it all back together and it runs better than it has since I bought it, other than this idle problem.
The idle problem is a bit odd to me. First fire up it is fine, drive or slowly rev it and the idle jumps to about 2k rpm. Then if I just quickly press the throttle about half way and release it, idle returns to 700rpm until I slowly press throttle, then the fast idle is back.
Gonna check everything again after work. Finished it at 2am this morning so I could get it driveable for work, so maybe i missed something in my exhausted state of mind.
Cel is on but that is due to the lower O2 sensor according to the codes I just had pulled . Just checked cam timing and its perfect, IACV is plugged in, all vacuum lines connected, can't check ignition timing until after work when I can get my timing light.
