ALARM question about IGNITION wires...
ok i got an alarm right. well i have like 4 ignition wires. here is the deal. says
IGNITON 1(secondary IGN. 1 Output)
IGNITON 1 (primary IGN. Output and alarm Input for IGN "ON")
ACCESSORY
what wire does where. i think the ACCESSORY is the one that has power on the second key position (like when your blower motor for ac/heater will work)
where do i hook up the other
most hondas use the same iginion setup but i have a 94 honda prelude si just incase.
ACCESSORY
ACCESSORY
ACCESSORY
ok here's the color's.
12V constant-- white-- steering column
IGNITION-- black/yellow-- steering column
ACCESSORY-- yellow-- steering column
STARTER-- black/white-- steering column
here's a side note, the 12v constant, the starter, and the ignition wires can all be found in the factory security plug located to the left of the steering column. the plug is gray in color, and there is a black wire in the plug that is a ground.
[Modified by rjr162, 11:24 PM 10/28/2002]
Isn't "Accessory" going to be any accessory you want to hook up to be triggered by a switch on the alarm fob? Like power trunk release, etc.?? I haven't hook up an alarm system in a few years, so maybe I'm just confused and don't remember.
hb_guy
Audio / Security / Video
Jan 27, 2008 01:23 PM
BoostedH23a1
Oct 29, 2002 09:35 AM
TurBoXBirD16
Feb 26, 2002 03:12 AM
