H22a7 project
Old Jan 6, 2014 | 10:26 AM
h22aseven's Avatar
Default H22a7 project
I have a 97 Accord sedan with a H22A7. What would some upgrades that I should start with. I want to stay n/a, would boring and upgrading the pistons be a good start and would I Want to do anything with the crankshaft?
Old Jan 6, 2014 | 10:32 AM
GhostAccord's Avatar
Default Re: H22a7 project
What is your budget and what are your goals and uses for this car?
What if any modifications do you have already and do you have a machine shop handy that can work on FRM cylinder engines?
I would say without knowing anything about your car, intake, header and exhaust. Then maybe a camshaft swap and some head work with larger valves and maybe some sort of upgraded intake manifold....individual throttles???? Your block is already in good shape for a well mannered street car.
if you want a monster H22 N/A build you can opt for sleeving the block and going with larger pistons... i would still start off rebuilding the top end first.
Old Jan 6, 2014 | 08:42 PM
h22aseven's Avatar
Ok...thanks for the advice. The is currently not my daily driver. I'm in Alaska , even with the LSD, I prefer the 4x4. I don't have a machine shop in mind yet. Just from the little reading I've done, I wasn't sure if I would even mess with pistons. It's seemed like people didn't mess with the pistons unless they are putting a turbo or supercharger on. I was thinking that I would have to build from the bottom up. Thanks for the tips.
Old Jan 6, 2014 | 10:25 PM
holmesnmanny's Avatar
That engine as stock is as good as they come. I wouldn't even mess with it.
crazes
17
Dec 30, 2008 01:28 PM
213374U
15
Jan 14, 2008 07:31 AM
kornerk12
Feb 13, 2006 02:42 PM
three6t
Dec 22, 2004 11:25 AM
Norcalstoppy
Dec 25, 2002 04:33 PM
