Transmission & Drivetrain Gearboxes, Differentials, Clutches
M2b4 trans.
Old Jan 6, 2014 | 01:55 AM
Soaskip's Avatar
Hello HT, just like to get some input and help. I'd like to start off by saying I'm not a master mechanic by any means so correct me if I use the wrong terms. Anyways I have an m2b4 trans id like to get rebuilt, and also keep in mind this will not be on a stock long block. Now I'd just like some help in transmission rebuilds, who makes a good rebuild kit that is going to with stand power but not break my bank? Also any info on teammfactorys final drives?
Old Jan 6, 2014 | 02:39 AM
Fliptard's Avatar
Default Re: M2b4 trans.
Sychrotech makes awesome parts for trans rebuilds. depending on how much you want to re-build it could get pricy. But they have excellent parts and specialize in Honda trans
Old Jan 8, 2014 | 04:00 AM
yungmulacrx's Avatar
Im running a synchrotech carbon syncro set with a mfactory final drive and have had zero issues.. Although im not pushing too much power through it.. You wont be able to use a mfactory final drive with the m2b4 differential.. You would have to find a oem 10 bolt lsd or a aftermarket lsd and also change the top case with a px5 case bacause the m2b4 14 bolt differential is a little wider.. I just bumped a thread with a similar setup..
my9thtry
Oct 24, 2016 12:38 PM
wilham320
Aug 10, 2014 12:06 AM
yungmulacrx
17
Jan 8, 2014 03:47 AM
coolcatsi
Jun 9, 2007 12:00 PM
C2Imports
Jun 13, 2005 06:30 PM
