99 civic lx crank but no start
Ok so i replace the fuel pump and the main relay new plugs and wires. Ok so the motor cranks over but will not fire up. All four plugs are getting fire. But for some reason the fuel injectors are not spraying. Theres pressure in the fuel rail but its notgetting to the cylinders. plugs remain dry. Also when I go to prime the fuel the pump stays running it never shuts off... please any help is appreciated
What motor is in the car? I helped my buddy solve a similar problem with his 99 ex (d16y8). Ended up that there's a block connector under the intake manifold, with multiple wires going to it. Being how it was loose floatin around under there one of the wires de-pinned themselves slightly from the connector causing the injectors to not fire. Can't hurt to take a look.
ESP.net
Apr 29, 2015 10:17 AM
95turboeg
11
Jun 13, 2013 03:51 PM
mshmink
Jan 30, 2013 04:04 PM
turbomikeg88
23
Mar 18, 2012 10:19 AM
Mr_Pushpop
Sep 10, 2010 02:38 PM
