No High Idle !! Why???
Old Jan 5, 2014 | 11:20 AM
TNight's Avatar
Default No High Idle !! Why???
Since the temp has dropped my 98 d16y8 Civic won't high idle at start. If I don't keep my foot on the gas she shuts off. I keep my foot on the gas for 30 sec. and she low idles way low around 200 rpm.
Runs and Drives fine.
Old Jan 5, 2014 | 11:35 AM
Former User's Avatar
Default Re: No High Idle !! Why???
Clean the IACV.
Any CEL codes?
Old Jan 5, 2014 | 06:08 PM
TNight's Avatar
Have recurring code for O2 but is actually Cat. Conv. issue
Old Jan 5, 2014 | 06:10 PM
TNight's Avatar
I guess it'll have to wait if it needs cleaning
minus 20 degree wind chill here
Old Jan 5, 2014 | 06:17 PM
Nope
Old Jan 8, 2014 | 07:52 PM
TNight's Avatar
How do you check the cat I have replaced the 02 and I suspect the cat is going. The Engine light comes on maybe for a week then its off for awhile
Old Jan 10, 2014 | 06:17 AM
92 civic ex 4dr's Avatar
The iacv needs to be cleaned as stated above. As far as a bad cat/o2 sensor. Are you sure you replaced the correct sensor and what brand o2sensor did you purchase?
Old Jan 10, 2014 | 07:09 AM
chillerice's Avatar
If you smell rotten eggs then it's gone. But I also think there's a tempeture inlet and outlet test you can do.
Clean or replace the IACV. Also if you can get the code that'd be better.
Old Jan 10, 2014 | 09:06 AM
marcelosm's Avatar
Now I may be confused but doesn't the fitv control the high idle on a cold startup? I thought the fitv allows more oxygen to enter the throttle body and raises the idle when the temp is low.
Old Jan 10, 2014 | 09:29 AM
goldsy's Avatar
The 96's and newer don't have a FITV.
Old Jan 10, 2014 | 09:42 AM
marcelosm's Avatar
Oh that makes sense. Thanks
ftrms
Oct 28, 2008 02:15 PM
hastingsr
Oct 16, 2008 12:34 AM
bricks2k4civic
Honda Civic (2001 - 2005)
May 21, 2006 09:44 AM
impr323
Sep 8, 2005 02:57 PM
DBallz
Jul 29, 2003 10:04 AM
