MAP are these readings normal
Old Jan 5, 2014 | 06:24 AM
afnan's Avatar
Icon2 MAP are these readings normal
My car is showing hesitation and some times bogging (cant go above 20 km/h even with full throttle).
I Tested the MAP
Switch On Engine Off
2.8Volts
Idle
1.2 Volts
Sudden Full Throttle and leave
2.7
Continous Full Throttle
2.7 and then keeps decreasing to 1.2 Volts
My Question is that these readings are normal?
Old Jan 5, 2014 | 11:52 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: MAP are these readings normal
I Tested the MAP
2.8Volts
Idle
1.2 Volts
2.7
With the key to ON and the engine off it should read as 0inHg, which would be same at WOT 0inHg since there is no manifold vacuum, which would be closer to 5 volts.
I'm guessing a dead MAP sensor, but before replacing that, back probe it with a DVM to monitor voltage outside of the ECU/PCM and before that make sure the air filter is not filthy, and that the air intake has not inhaled a small bird or mammal. But since it does it with the KOEO I'm guessing dead MAP. Check all ground wires and cables too.
dc101
Jun 1, 2011 06:21 PM
DeucesGoneWild
12
Feb 22, 2010 10:02 PM
mikeunreal
Oct 26, 2005 05:31 PM
boostincoupe
Sep 3, 2005 01:54 PM
