h23aV Wiring help?
Old Jan 4, 2014 | 06:01 PM
r1cerocket7o2's Avatar
Default h23aV Wiring help?
Hey guys got the h23aV and wondering if you guys know if im able to use my old harness h23a1 non-v? from 92 lude and solution's for v-tec solinoid hookup to run on ecu? h23av came with all wiring harness should i use the obd2 harness and just convert obd1 to obd2
Old Jan 5, 2014 | 12:05 AM
holmesnmanny's Avatar
Default Re: h23aV Wiring help?
just pick up the h22a1 obd1 ecu and a vtec kit and wire it in yourself...really easy...just google axidworks if you want to get a readymade kit
you already have iab's and knock sensor on your original harness so no big deal...don't use the obd2 harness not necessary
Old Jan 8, 2014 | 04:51 PM
Thanks that helped alot how about the distributor only has the 8 pin will it work without the 2 pin for dist.
Old Jan 13, 2014 | 03:04 PM
Rosko's Avatar
Use you H23a1 distributor and external coil and H23a1 harness and all you will need to add is the vtec wiring.
JDM-97CX
Aug 15, 2005 08:54 AM
Cesare
Jun 5, 2005 03:54 PM
Honda_Tengoku
Sep 12, 2004 02:08 PM
egturbo
Jan 11, 2004 09:45 PM
NO_FEAR_LWO
Aug 29, 2003 03:42 AM
