Wiring help needed (searched)
1 Post
Re: Wiring help needed (JDM-97CX)
Out of all the people on this site, there has to be some one that has put an OBD1 motor in an OBD2 vehicle. I need the wiring diagrams to modify the harness.
Just do the opposite of the OBD2 engine into an OBD1 car. https://honda-tech.com/zerothread?id=550976 Change the 2 wires for the distributor, swap the voltage regulators in the alternators (I'd assume if it worked one way, it'd work the other way), and use stock injectors. You'll also need to get an OBD2a to OBD1 conversion harness to plug in the ECU. Then run lines for vtec: http://www.allmotorhonda.com/t...g.htm
FritzInTN
07-10-2004 09:45 AM
underb00steg6
06-13-2003 11:43 AM
