B16 EG ac bracket trouble
I'm trying to use the stock under frame torque mount on my 94 hatch with my B16. I have a GSR bracket and things aren't wanting to line up at all. Is there a difference in the GSR and B16 ac bracket? Can anyone tell me which bracket I need to use to solve the problem? Thanks
From: Pensacola, FL and every Court House in Louisiana
You need a ac bracket from a USDM crv or off a delsol vtec with the b16. They are the only two that will fit with a swap in a eg.
If it's a B16A and you have power steering you need the Del Sol VTEC bracket, if it's a B16B or any other B-series you can use either the Del Sol or CR-V bracket, you can also use the CR-V bracket on a B16A if you don't have power steering.
jadugartir
Aug 19, 2006 12:30 PM
civic_tuner
Apr 8, 2005 07:36 PM
