d15 d16y8 mini me swap mpg, power, ?
Old Dec 31, 2013 | 08:32 AM
65impala's Avatar
Default d15 d16y8 mini me swap mpg, power, ?
I am planning a budget build and ran across this y8 head and intake . Would this be a good combo for mpg and fun ? I was going to mill stock head and ad cam.
Old Dec 31, 2013 | 08:43 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: d15 d16y8 mini me swap mpg, power, ?
i had this same motor. b7 block and y8 head. made mad power over a stock b7.
had vtec at 4500. make sure the bottom end is in good shape though. yeilds good compression. use the honda compression calculator
Old Dec 31, 2013 | 11:13 AM
65impala's Avatar
do you know what your gas millage was?
Old Dec 31, 2013 | 11:20 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Use the same injectors and still a 1.5 liter, so if you don't get on the peddle (stay out of vtec) your mpg should be similiar. You are using a 1.6 ecu map sorta, if you get it tuned.... should maintain mpg when driven casual.
liljukmoves
19
Aug 12, 2020 02:58 AM
shawnperolis
17
Aug 30, 2013 11:19 AM
SoUrEdHaLo
Oct 21, 2009 05:04 PM
turbod16y7vtec
Aug 20, 2002 11:56 PM
mini-cRx
Apr 19, 2002 07:09 AM
