Honda CR-V & Element 2WD & 4WD Element & CR-V
02 crv rough idle, stalling and engine noise/knock
Old Dec 29, 2013 | 02:16 PM
bcool's Avatar
Default 02 crv rough idle, stalling and engine noise/knock
My crv had a jumpy idle for some time now but today it was dropping all the way down and stalling. When i popped the hood i noticed a loud knocking noise while its running (rough).. Could this be a timing/valveissue or camshaft?
My crv has 133k
Old Dec 29, 2013 | 03:40 PM
skill178's Avatar
Default Re: 02 crv rough idle, stalling and engine noise/knock
valves typically sound more like a tick. did it make the noise before it started stalling?
Old Dec 29, 2013 | 04:17 PM
bcool's Avatar
No just after it started stalling.. I doubt it has anything to do with this but i just changed the oil yesterday oil levels are still good... Could a bad cam shaft sensor cause it to stall and make a noise?
Old Dec 29, 2013 | 04:23 PM
skill178's Avatar
it would throw the check engine light if it was a sensor, also ive never had a cam sensor go bad on a CRV but i have with other cars and they didnt start at all. though i have seen a K20 jump cam timing easy, it made a ticking sound and would not run, vavles hitting the pistons just slightly.
how many miles on the car?
Old Dec 29, 2013 | 04:44 PM
bcool's Avatar
133k on the car.. Ive had it for about 25k and never did a valve adjustment since ive owned it
Old Dec 29, 2013 | 05:04 PM
skill178's Avatar
alot easier to diagnose if i could hear it, never seen the lack of adjustment keep a car from running unless the valve breaks. any record of previous owner changing the chain/tensioner?
Old Dec 29, 2013 | 05:18 PM
bcool's Avatar
No i dont have any records for it.. Ill try to post a video of it tomorrow after work
Old Jan 1, 2014 | 10:38 AM
bcool's Avatar
It turns out i have a bad a/c pulley that was prob causing all these problems.. CAn i bypass the a/c with a shorter belt or do i have to buy an a/c pulley bypass?
Twistedframe
May 27, 2022 05:28 PM
acracer2008
Aug 2, 2010 05:35 AM
stocky
Mar 15, 2007 06:23 AM
vrrodri
Dec 18, 2002 11:49 AM
servion
May 7, 2002 02:07 AM
