Cylinder Position Sensor Malfunction ??? Code 9
Old Oct 28, 2002 | 09:22 AM
DeeperFOLK's Avatar
Default Cylinder Position Sensor Malfunction ??? Code 9
What exactly does "Cylinder Position Sensor Malfunction" mean? This message seems to like to pop up every now and then, and it really annoys me. Could someone pop this message into lamen terms please.
Old Oct 28, 2002 | 09:47 AM
Stew Pidasso's Avatar
Default Re: Cylinder Position Sensor Malfunction ??? Code 9 (DeeperFOLK)
Nothing to really worry about...
Check out this thread.
https://honda-tech.com/zerothread?id=316249
Old Oct 28, 2002 | 10:06 AM
DeeperFOLK's Avatar
Default Re: Cylinder Position Sensor Malfunction ??? Code 9 (Stew Pidasso)
Cool Thanks man. It just seems to come on every month. I'm pretty slow when it comes to car mechanics... Where would the dist cap be so i can check if the wires are still on correctly?
Old Oct 28, 2002 | 10:27 AM
carolinaACCORD's Avatar
the dist cap is the black circular plastic thing that all of your spark plug wires go into. simply unscrew the screws, and remove. the wires that you need to check are behind the rotor, you'll have to turn the engine over to make the screw for the rotor visible. once you have that off, you'll see the wires.
Old Oct 28, 2002 | 10:38 AM
DeeperFOLK's Avatar
Default Re: Cylinder Position Sensor Malfunction ??? Code 9 (carolinaACCORD)
ahh well... Heh..heh.. That seems like alot of work that, I, personally should not be doing. I'll probably break something. I'll just hope that they are. I went and go a tune up about a month ago and they probably would've noticed if something was wrong, so i just won't touch that. Thanks to the both of you.
iponnet
Feb 21, 2011 07:58 PM
djviet2000
Aug 3, 2010 02:03 AM
JonGP4
14
Jul 26, 2003 10:45 AM
XtremeCarTuner
Jul 10, 2003 07:48 PM
scratchline20
Jun 4, 2003 08:14 PM
