Starting issue
Old Dec 22, 2013 | 07:55 PM
ElswickB22's Avatar
Default Starting issue
Hey guys, I have been having a weird problem with my 98 CX hatch. Its a mini me swap with intake. The problem is sometimes that car will start and stall out. It occurs most when the car is up hill or uneven. At first I thought it was battery or battery connections but I got the battery charged and new connections. It has happened allot recently.
Any help would be greatly appreciated.
Old Dec 22, 2013 | 11:38 PM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
Default Re: Starting issue
Only thing that has to do with slope starts or uneven ground starts,
Something in fuel system I believe.
Possibly clogged lines, bad fuel pump.
Old Dec 23, 2013 | 12:15 PM
ElswickB22's Avatar
That's what I thought as well. I tried just priming the system a few times before I would start it on a slope n it was a little better. But after its started and I give it a little gas its fine.
Old Dec 23, 2013 | 04:12 PM
Shit Posts: 15
10 Year Member
Check your fuel pressure.
If priming helps, maybe a bad pump or dirty fuel filter
Old Dec 23, 2013 | 05:12 PM
Steebhouse's Avatar
Distributor cap, maybe? I don't know.
Old Dec 24, 2013 | 12:22 PM
waynesumner's Avatar
keep a half tank of gas or more at all times? I too am having this issue on slopes. it just started and im below a half tank, never had this issue prior to being so low on fuel. just a suggestion.
Old Dec 24, 2013 | 02:51 PM
existanzcivicb20's Avatar
Take the fuel pump out clean the little net/filter thing and look inside the tank for rust or trash in there
Old Dec 24, 2013 | 06:33 PM
dnice78's Avatar
Sounds like your fuel pump is going out, swap it out with a buddy to diagnose?
Zigory
Honda Civic (2001 - 2005)
Apr 1, 2019 08:19 AM
ninjaturtleEG
Sep 14, 2016 11:15 AM
Fowler.
10
Aug 20, 2004 05:26 PM
5starJ
Mar 15, 2004 03:41 PM
b16_incarnate
Oct 5, 2002 10:23 PM
