boosted gsr cutting out
Old Dec 21, 2013 | 10:36 PM
fi_ickenfast's Avatar
Icon2 boosted gsr cutting out
96 civic hatch
gsr turbo
67mm turbo
moran motorsports 1000cc injectors
sk2 cams and valvetrain
81mm block
rods and pistons
edelbrock im
obd1 jumper
hondata s300
hondata boost controller
gm 3bar map
tested tps, map, main relay, all fuses. distributor, wires, plugs are good.. fuel pump is ok. took it for a test drive and at 5375 rpm it cuts off. looked at the logs and the sensors said boost cut, fuel cut and ign cut with only 5 psi. never even got to vtec. My boost cut is set at 26psi.
when i unplugged the vtec solenoid, took it for a test run and it went fine. checked oil pressure going to the vtec solenoid, and its fine. Changed the Solenoid and oil pressure switch.. The screens are clean...Wiring to the ecu is correct with no burnt wires.
I also tried a hondata 4bar map sensor...
last time at the track the car was cutting out, but when power shifting, it goes well. when returning back on the return lanes I opened up 2nd gear and the just cuts at vtec
so basically its hitting a boost, fuel , and ign cut right before vtec
any help will be greatly appreciated...
thanks for reading
Old Dec 26, 2013 | 12:28 PM
VegasInvasion's Avatar
I'm Huge In Japan
Default Re: boosted gsr cutting out
there's no way we can help with this kind of problem without seeing a calibration and datalog file.
Old Dec 27, 2013 | 04:12 PM
juba_x's Avatar
Is the any cel?
Old Dec 29, 2013 | 05:56 PM
IN VTEC's Avatar
It's interesting that it doesn't do it with the HIGH cam turned off.
I had a similar issue when I took my car to Evans Tuning. It would CEL for boost cut at 5-6 psi even tho the cut was set at 15 psi. It happened driving up to the shop but stopped after a new calibration was uploaded. The session was completed without a hitch. Jeff said he had seen it before with similar remedy.
If the mechanical parts check out and it still doesn't make any sense, the software may be the problem. It can't hurt to try.
fi_ickenfast
Engine Management and Tuning
17
Dec 21, 2013 09:45 PM
TurboSohc3369
Nov 14, 2013 12:05 PM
TurboSohc3369
Nov 14, 2013 08:29 AM
lexrob
16
Mar 6, 2010 04:49 PM
siis2fast
Jun 12, 2003 08:56 AM
