1998 CRV wont start, doesn't turn over...
My CRV just started having issues last week, it wont start after driving it for a while. For example, I'll go drive for 25 minutes, come back and once in a while after i shut the car off it wont start up again. All i hear is a "click" when i turn the key, the car will not turn over. It doesn't do this every time, only once in a while
I have replaced the starter and all the battery terminals, the battery is fairly new so i haven't tried replacing that yet. Boosting the car does nothing btw
Note: when i turn the key and try to start it an exclamation mark comes up on my dashboard, the same light that comes up when you pull the handbrake
Any ideas?
Any ideas?
Check for any codes first. Most auto parts stores will read them for free if you don't have a diagnostic tool available to you. If no codes then it's probably the relay or ignition switch.
Ok so i took it for a drive (~30min) came back to my place, turned it off and tried to start it and it did the same thing. I should mention that it ONLY does this once the engine has warmed up, its never done it cold.
I tried to start it in neutral without any luck, i managed to get it started a few more times just by using my automatic car start and also by just turning the car off and on. Eventually after about 4-5 starts doing this it stopped starting all together, i took a video of what happens for you guys.
I'm at work now so I can't watch the video but if I understand correctly, you are saying that you can't start it with the key when it's warmed up but it will start with the remote starter?
If that's the case, I can only see it being related to the ignition switch. Strange that it only happens when it's warm though.
Sometimes only the key works to turn it on and sometimes only the remote start works to turn it on.
thexbrothers
Oct 12, 2013 11:49 AM
john'sD16Aek
Engine Management and Tuning
Jan 15, 2013 02:42 PM
