93 hatch cooling system problems
I have a 93 Civic hatch with a brand new ls-vtec turbo. Motor was just put together with all new parts. Got everything together and started. Went through all the proper steps. While trying to bleed the cooling system noticed the radiator was getting very hot and coolant was extremely hot. Temp gauge on dash showing just under half way. Upper radiator hose is hot to the touch but lower radiator hose has no heat to it at all.
Vehicle info:
Stock ls water pump
Bisimoto 170° thermostat (brand new)
Dual core radiator
Spal fan wired to always run
Think maybe a bad thermostat. I know factory temp gauges aren't that accurate but it has a brand new temp sensor and all wiring is good.
Any opinions greatly appreciated!
Vehicle info:
Stock ls water pump
Dual core radiator
1991crx16
14
Jan 26, 2011 01:47 PM
0260MOTORSPORTS
Dec 15, 2006 10:47 PM
