Compression test results
Old Dec 18, 2013 | 01:03 PM
Vladglad's Avatar
Icon3 Compression test results
So yea... This is my compression test results....I put the spark plugs in there of it can give clues
Old Dec 18, 2013 | 01:07 PM
Vladglad's Avatar
Icon3 Re: Compression test results
Ummm so yea this is my compression test results.....horrible cyl rings or valve stem seals ?
Old Dec 18, 2013 | 01:09 PM
Vladglad's Avatar
Default Re: Compression test results
Cyl2
Old Dec 18, 2013 | 01:10 PM
Vladglad's Avatar
Cyl3
Old Dec 18, 2013 | 01:11 PM
B_Swapped93's Avatar
It being that low along with the obv signs you're running rich(plugs are black) I vote either washed cyl walls or burnt/warped valves you can do a leakdown test if you like but that's way to low. had warped valves on my civic once paused something like 0,60,100,160 lol replaced valves 210-212 1-4 . in the case of washed walls well swap time...
Old Dec 18, 2013 | 01:12 PM
Vladglad's Avatar
Cyl4
Old Dec 18, 2013 | 01:15 PM
Vladglad's Avatar
im kinda new what do you mean by washed cyl walls ???
Old Dec 18, 2013 | 01:19 PM
too much gas into the cylinder will cause a "rich" condition which in turn will "wash the cylinder walls" effectively destroying your compression, only fix hone the cylinder or swap a new bottom end. That's probably not the case unless the engine had low compression to begin with so I think it's more then likely the valves.
Old Dec 18, 2013 | 01:27 PM
Vladglad's Avatar
too much gas into the cylinder will cause a "rich" condition which in turn will "wash the cylinder walls" effectively destroying your compression, only fix hone the walls or swap a new bottom end. That's probably not the case unless the engine had low compression to begin with so I think it's more then likely the valves.
thnx for the explantion i think the car had low comp to begin with so i to think its the valve stems seals becouse in my other post i was asking about valve lash adjustment becouse im hearing loud ticks from there so yea
Old Dec 18, 2013 | 01:33 PM
leakdown test to confirm where it's leaking from. a garage will do one for like 40$ or free if they're cool. or if you have a compressor and the kit DIY. last thing i'll suggest is a wet test to see if it's the rings which would be due to it just being old. post wet test number if you can do it.
Old Dec 18, 2013 | 01:38 PM
pityocamptes's Avatar
Did you do the test with all the plugs removed and at Wide Open Throttle?
Vladglad's Avatar
im NOOB how would you do a wet test one and yes i have compression and the comp test kit and i know how to do the downleak test so ill do so if i hear/feel air coming from the TB then its the valve stem seals and if i hear/feel air form the oil pan then its the rings and if bubbles come out the raidiator then its HG rigth? lol
Old Dec 18, 2013 | 01:40 PM
Vladglad's Avatar
i did it with all the plugs/Sparks removed and no not at wide TB
Old Dec 18, 2013 | 01:41 PM
You have to do it with all plugs removed and wide open throttle for accurate reading...
Old Dec 18, 2013 | 01:42 PM
Try it at WOT and post your numbers... a wet test is you squirt a little oil into each cylinder and test again at WOP and read compression. If it changes significantly it suggests your rings are bad. Try the reading at WOT dry (without the oil in the cylinders) first...
Old Dec 18, 2013 | 01:51 PM
Vladglad's Avatar
WOT ?? sorry i dont know all the terms yet
Old Dec 18, 2013 | 01:54 PM
NotARaCist's Avatar
I never narc'd on nobody!
WOT = wide open throttle.
Old Dec 18, 2013 | 01:57 PM
Wide Open Throttle and you may only gain 10psi from doing it it's recommended but not a game changer in this case. as the other poster said just a bit of oil into each cyl. Also unplug the injectors and unplug the distributor, good way to wash the walls even worse if you didn't in the first place and a good way to kill the coil.
Old Dec 18, 2013 | 01:58 PM
You will need to pull all the plugs, connect the gauge, and while cranking push the gas pedal all the way to the floor...
Old Dec 18, 2013 | 02:07 PM
Vladglad's Avatar
i read how to do it so i had the injectors unplugged/dizzy okay ill do the downleak test and the wet test tomorrow and post results here
Old Dec 18, 2013 | 02:56 PM
apexi_rsx's Avatar
if compression is consistant and normal readings with a cap full of oil down the hole its ur rings. if ur compression test nets the same numbers its time to pull the head as its a valve issue... no need for the leakdown
SilkyJohnson
13
Feb 15, 2011 05:54 PM
The Dirty EJ1
Jun 30, 2008 12:37 AM
humboldt_skim
May 31, 2008 08:18 AM
Sport_Injected
Aug 25, 2004 09:21 PM
EF8_SiR
Jul 20, 2003 10:24 PM
