I think my cars previous owner wrecked it
Old Dec 16, 2013 | 05:31 PM
ajbardo's Avatar
Default I think my cars previous owner wrecked it
is there any way to measure from strut tower 2 core support to find out if my front end is square?
Old Dec 16, 2013 | 05:38 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: I think my cars previous owner wrecked it
Sure, use some string and do some basic carpentry. It's called measuring a square. Your core support and frame should be the same across diagonal lengths.
Old Dec 16, 2013 | 05:47 PM
B_Swapped93's Avatar
Do the body panels line up ? if yes then don't worry if not it could be the panel it's self vs the actual frame.
Old Dec 16, 2013 | 06:14 PM
shocker911's Avatar
get a buddy a tape measure and go online and look for "crash book" measurements. This way you can go off of what it should be
Old Dec 16, 2013 | 06:17 PM
belairbrian's Avatar
my factory shop manual has all the dimensions in the body chapter.
And you can't rely on how body panels line up. You can have shock towers a little out or suspension points moved and still align the body panels.
Old Dec 16, 2013 | 06:51 PM
ajbardo's Avatar
The panel do not line up. its a 98 civic with a 2000 Frontend
Old Dec 16, 2013 | 06:52 PM
ajbardo's Avatar
Belair. Can you please get me the front end number?
Old Dec 17, 2013 | 04:27 PM
Do you have a del sol?
Old Dec 17, 2013 | 05:58 PM
ajbardo's Avatar
Crap. Was hoping your fsm covered civics as well
Old Dec 17, 2013 | 06:02 PM
You do know that's a popular conversion just like doing the 98 front on the integra's all it is, is the front bumper. Doesn't mean it was crashed....
Old Dec 17, 2013 | 06:35 PM
ajbardo's Avatar
Yes I do. It's a hood, bumper, grill and headlight swap. The wrinkled up inner passenger side fender and pass door hitting the back of the fender is what tells me is was in a crash
Old Dec 18, 2013 | 03:57 PM
ajbardo's Avatar
So no one has any info on this?
Old Dec 19, 2013 | 09:00 AM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
I don't have the manual so I can't give you the numbers. If you can't find anything on the internet, most library's carry car manuals.
On the other hand, if you do what NotARacist suggested, you don't need to know what numbers you should get. All you need to determine is if the numbers match when you measure the diagonals. Cars have points all over for frame guys to measure when repairing crash damage.
Search for how to square a frame wall. Same principles.
Old Dec 19, 2013 | 09:29 AM
pityocamptes's Avatar
Order a carfax report?
Old Dec 19, 2013 | 09:36 AM
CX-Adam's Avatar
talks to himself
Community Builder
Only contains information that's been reported. A lot of people don't claim accidents. In no way are the definitive and I, personally, think they're a scam.
Old Dec 19, 2013 | 09:45 AM
True, but wouldn't hurt...
Old Dec 19, 2013 | 09:46 AM
Its probably pretty obvious based on OP's description that it was trashed. Inner fenders, etc. all tore up... I would be looking for new weld joints, etc...
OP, even if you find out it was wrecked, what do you realistically plan on doing?
Old Dec 19, 2013 | 02:35 PM
ajbardo's Avatar
Not buying a carfax on a 300$ car. If the car was wrecked I'm not going to do anything but use it as a dd till it dies. If not I was going to replace the boogered up fender and swap it to a 5speed and throw some parts at it.
Old Dec 19, 2013 | 08:27 PM
ajbardo's Avatar
I guess I should say I don't care if was wrecked as long as everything was squared up and not going to cause problems
Old Dec 19, 2013 | 08:39 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
if it's just a beater, you might be able to chain it down and use a come along and a tree to pull that side back into something reasonably square, I've seen plenty of people do it, just pull a very small amount and measure measure measure
Old Dec 19, 2013 | 10:48 PM
ajbardo's Avatar
If its good and square then I'm good if not f it.
Old Dec 20, 2013 | 02:03 PM
GOLF BRO's Avatar
post pictures of the car so we can see what youre talking about
Old Dec 21, 2013 | 10:24 PM
ajbardo's Avatar
I'll get off of work early today, I'll post pics then. Can I post them on here or do I have to link them from photobucket?
Old Dec 22, 2013 | 11:46 AM
ajbardo's Avatar
ajbardo's Avatar
I do not know how to resize. The first pic is from when the po opened the pass door after swapping the new front but before checking the gaps. The 2nd pic is looking down between the air box and the pass inner fender. You can't see it in this pic but it looks like some of drilled holed and tried to pull this piece out. I also found body filler in this location and on top of the strut tower.
