Do you need a flex pipe??
Old Oct 28, 2002 | 05:58 AM
1tyme's Avatar
Default Do you need a flex pipe??
is it necessary to use a flex pipe to connect the downpipe to the exhaust?
Old Oct 28, 2002 | 06:01 AM
falcongsr's Avatar
What is this crap?
Default Re: Do you need a flex pipe?? (1tyme)
are you using the stock exhaust with those spring loaded bolts? if not then i believe the answer is yes always.
Old Oct 28, 2002 | 06:13 AM
chirish's Avatar
Default Re: Do you need a flex pipe?? (falconGSR)
It's a good idea, metal expands when hot and you need that "flex" in order to prevent cracking, etc.
Old Oct 28, 2002 | 06:24 AM
falcongsr's Avatar
What is this crap?
Default Re: Do you need a flex pipe?? (PssshhhMr2)
the main problem is the engine rocking. if you have ever seen a dyno run on a stock engine (with stock motor mounts) you'll see the whole motor flex back and forth like +- 3 inches as it tries to rotate around the drive axles.
Old Oct 28, 2002 | 08:02 AM
1990hondaHF's Avatar
They are so cheap anyway, so why not. I can't see saving $30.00 only to crack your $300.00 header or worse break it off at the head! Go to JCWhitney, they have great prices.
Old Oct 28, 2002 | 08:07 AM
symba's Avatar
Default Re: Do you need a flex pipe?? (1990hondaHF)
I'm still learning, but IMO that's like spending big dollars on a Precision BB turbo and then putting rubber hoses with holes in them as your oil feed line
Old Mar 23, 2003 | 07:11 PM
integra-modder's Avatar
Im building a 3 inch exhuast for a daily driven car.
Im trying to decide whether to purchase a flex pipe. It'll be about 75 bucks extra installed.
My theory is since the car has more power and torque, the engine will want to move around more, and increasing the changes of braking a part of the exhuast system.
Is that a good theory or not?
Old Mar 23, 2003 | 07:39 PM
Tofurky's Avatar
Default Re: Do you need a flex pipe?? (integra-modder)
from what i've seen, it's important to have one. my neighbor went through 2-3 greddy downpipes before realizing that they broke due to the absence of a flex pipe.
Old Mar 23, 2003 | 08:17 PM
intekragsr's Avatar
Default Re: Do you need a flex pipe?? (Ruckus138)
i need flex pipe. They completly screwed up the bolts on the turbo and I had to retap the exhaust housing.
Old Mar 24, 2003 | 02:32 AM
Default Re: Do you need a flex pipe?? (intekragsr)
good thing, because i just ordered a flex pipe....
thanks guys
Old Mar 24, 2003 | 05:52 AM
B18C4-T's Avatar
I'm getting ready to order a 3" downpipe, but I've broken the weld from my downpipe to my cat 3 times. I will definitely put a flex pipe on my new downpipe.
Old Mar 24, 2003 | 08:36 AM
SiR Kid's Avatar
New User
Default Re: Do you need a flex pipe?? (B18C4-T)
Here's what happened to mine because of a broken <HaSport> rear motor mount, BUT the same thing could happen from lack of flex pipe!
Old Mar 24, 2003 | 08:54 AM
psi420's Avatar
Default Re: Do you need a flex pipe?? (SiR Kid)
Same EXACT ting happened to me when I first put turbo on.
I installed a flex pipe with the new downpipe, no problems since.
Old Mar 24, 2003 | 01:00 PM
Default Re: Do you need a flex pipe?? (psi420)
thanks for the reasuring thoughts that my 75 bucks wont goto waste...
Old Mar 24, 2003 | 01:39 PM
turbospool's Avatar
how did you break your hasport rear mount?
Old Mar 24, 2003 | 03:19 PM
Default Re: Do you need a flex pipe?? (turbospool)
please you personal messages for conversation off topic to the post
tlchkc
16
Nov 23, 2009 09:14 PM
EcRzFinesT
10
Nov 20, 2009 09:40 PM
092eg6
Oct 17, 2009 10:50 PM
MulticolrdLude
Jul 6, 2007 12:40 AM
matix
Dec 6, 2004 05:05 AM
