quick check up on ek b20 swap
Old Dec 15, 2013 | 11:43 PM
raverx3m's Avatar
Default quick check up on ek b20 swap
required parts to swap into ej6
civic cx hatch non vtec
a jdm b20b will work with stock d16y7 harness if i relocate the O2 sensor plugs?
i need motor axles engine mounts and do i need a diffetent shift linkage?
and can a stock crv ecu be used with it? from a b20z engine? that way i dont have to get the obd2 to obd1 adapter
Old Dec 16, 2013 | 01:18 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: quick check up on ek b20 swap
General swap parts
http://bc-garage.com/2012/10/21/b-se...ne-swap-guide/
You'll need to have a cat welded on as well with an O2 bung after the cat or in it similar to an EX/Si cat.
Wiring (https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-00-honda-engine-swap-wiring-guide-vtec-non-vtec-2987229/)
-the IAT plug will differ
-bypass CKF sensor at the crank
-extend secondary 02
-3-2 wire IACV conversion
CRV ECU will work as long as you match OBD2 for OBD2 so that you don't need an adapter and makes sure you have all the applicable EVAP parts. However the B20Z ECU will look for a knock sensor so make sure your engine has one.
Old Dec 16, 2013 | 10:03 AM
raverx3m's Avatar
yep it has the knock sensor its the jdm b20b from 2000 crv
why do i need to bypass the cfk sensor the b20 has one also(i thought i saw the plug)
Old Dec 16, 2013 | 11:04 AM
Technical Hero
If its JDM it shouldn't have a CKF
Old Dec 16, 2013 | 01:24 PM
raverx3m's Avatar
Oh yea lol brainfart
sureshot007
Aug 31, 2020 07:05 AM
BokudenNYC
14
Aug 4, 2009 07:29 AM
afplayboy17
Apr 10, 2009 03:31 PM
s2k drifter
May 2, 2005 09:50 PM
MAD SCIENTIST
May 6, 2004 11:01 PM
