Fuel Rail Question.
Old Dec 15, 2013 | 08:55 PM
hylaxrng's Avatar
Default Fuel Rail Question.
b16a2 fresh rebuilt head instlaled tried geting fuel pressure before start, i have a bul fuel rail its leaking/spraying from banjo bolt just small spray and leakage, but still leakage.
what type of washer and what materiel do i use for replacements.
also do i line up the holes to the banjo bolt and the rail?!?!
banjo has two prongs sticking off of it.
Uploaded with ImageShack.us
Old Dec 15, 2013 | 09:17 PM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
Default Re: Fuel Rail Question.
Those use copper washers
What prongs are you talking about?
Or are you referring to the two ports on the banjo bolt??
Those don't line up with the hose, the end of the hose is open all around so regardless the banjo bolt position, it will get fuel,
Get the copper washers and tighten it up
Or torque it
11 lb/tq
Old Dec 16, 2013 | 05:05 AM
B_Swapped93's Avatar
you're probably missing the washer the prongs you're talking about are just a guide line of where to line up the bolt to rail's end.
horn12007
Nov 8, 2010 10:12 AM
civictype-r
May 26, 2010 08:30 AM
jpnucrx
May 14, 2006 09:30 PM
civickiller
Mar 27, 2004 06:43 PM
Sephro
Jul 29, 2003 10:37 AM
