What is this called?
Old Jul 29, 2003 | 09:57 AM
Sephro's Avatar
Default What is this called?
Okay I just put my motor back in the car connected everything up went to tighten the bolt that you let the pressure out of on the end of the fuel rail and I snapped the smaller bolt that goes into the larger one. I need to find one ASAP but don't know the name for it. Does anyone know the name so I don't have to describe it to every place I call?
Thanks
Old Jul 29, 2003 | 10:09 AM
iakona's Avatar
i do believe that is the banjo bolt for the end of the fuel rail. does it have a little hole in it?
Old Jul 29, 2003 | 10:16 AM
Sephro's Avatar
Default Re: (iakona)
yeah it has a hole in it. It's a large bolt with a hole through the center that has a smaller bolt in it. It's on the drivers side of the fuel rail. I believe that it's only purpose is to let the pressure out of the system.
I just did a search for banjo and I found this pic. It is not this connection. There is no hose going into it. It's on the other end of the fuel rail
Modified by Sephro at 2:27 PM 7/29/2003
Old Jul 29, 2003 | 10:21 AM
98boostedlude's Avatar
Default Re: (Sephro)
Yeah, that should be the banjo bolt that attaches the fuel line to the rail, and it has two washers to go with it, one on each side.
Old Jul 29, 2003 | 10:27 AM
Sephro's Avatar
Default Re: (98boostedlude)
No it's not that one. It's on the other end of the rail. It has no lines going into it.
Old Jul 29, 2003 | 10:37 AM
Sephro's Avatar
I think I may have found it but they just call it a bolt It's #25 and #26 I believe. Is there a name for it??
Modified by Sephro at 2:47 PM 7/29/2003
hylaxrng
Dec 16, 2013 05:05 AM
horn12007
Nov 8, 2010 10:12 AM
civictype-r
May 26, 2010 08:30 AM
CHEFH22HATCH
Oct 10, 2007 09:22 AM
