Valve ticking
Old Dec 15, 2013 | 11:48 AM
Vladglad's Avatar
Icon2 Valve ticking
On my 97 ex just recently started to hear noise from the head and then found out it was valve ticking so here comes the real question I've asked a Freind he siad to retard the ignition timing until the valves stop tickling but when I did some research it say it's mostly for Diffrent power out puts in rpm ranges so back to what I have to say I only hear the valve noise around 2k-4ish if that could give any clues so do I have to do valve lash adjust and check my mechanical timing ? Thnx any help will be appreciated
Old Dec 15, 2013 | 12:49 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Valve ticking
Ignore your friend, and do a valve lash adjustment.
Old Dec 15, 2013 | 01:51 PM
B_Swapped93's Avatar
some tap is normal on these older Honda's but as said check lash and adjust if needed.
Old Dec 15, 2013 | 06:40 PM
Vladglad's Avatar
thnx guys umm also what if my mechanical timing is off how would i fix that do i have to take my timing belt off to do that and thnx agian btw could a lose timing belt cause vlave ticking like as in very loud
Old Dec 15, 2013 | 06:43 PM
NotARaCist's Avatar
If your mechanical timing is off, you would need to remove the belt, readjust everything, then reinstall. You would notice other problems, though, if you had jumped a tooth.
Old Dec 15, 2013 | 06:49 PM
Vladglad's Avatar
umm can u list some problems that could acur if i have a jumped tooth like would bad idle be one ? and thnx for the advice man
Old Dec 15, 2013 | 07:54 PM
ajbardo's Avatar
loss of power would be the biggest problem.
Old Dec 16, 2013 | 03:35 AM
Vladglad's Avatar
loss of power as in when ur flooring it and you can feel all your power stop around 4k rpm then pick back up after vtec and then start acting hella weird around 6500k rpm like in *** when u hit 6500k rpm it starts to sputter ??
Old Dec 16, 2013 | 11:58 AM
Vladglad's Avatar
Also what feeler Guage would you guys recomand ? Found some on snap on they any good
Old Dec 16, 2013 | 12:05 PM
No it wouldn't cause a noticeable loss why ppl speared that is beyond me, you'd loose a few psi of compression but not enough to feel it. As for your question ANY will do no need for a fancy feeler gauge.
Old Dec 16, 2013 | 03:07 PM
ajbardo's Avatar
because when my Dodge jumped 1 toothyou would notice a large drop in power
Old Dec 16, 2013 | 03:48 PM
Vladglad's Avatar
Would these do the job ?
Old Dec 16, 2013 | 03:51 PM
yes those would do fine.
@ajbardo are you talking about mechanical timing being off or lash being out of spec two different things...
Old Dec 16, 2013 | 04:07 PM
ajbardo's Avatar
I know. I was replying to this question.
Old Dec 17, 2013 | 09:21 AM
Vladglad's Avatar
@b_swapped93 I also would need this tool to ?
Old Dec 17, 2013 | 09:33 AM
yes^ it's virtually impossible without it.
Old Dec 17, 2013 | 09:49 AM
Vladglad's Avatar
Thnx for all the help man I ordered all the tools and will be dion the lash adjustment soon thnx agian for all the help
Old Dec 17, 2013 | 06:15 PM
ajbardo's Avatar
no its not. Use a 10 millimeter closed end wrench and a flat head screwdriver. A friend of mine and myself adjusted my valves in 40 minutes using that method.
Old Dec 17, 2013 | 06:22 PM
no its not. Use a 10 millimeter closed and wrench and a flat head screwdriver. A friend of mine and myself adjusted my valves in 40 minutes using that method
On a VTEC B-series yah it's 100% impossible, heck I'm 90% sure it's impossible to do it without that tool on DOHC engines I assumed OP had a swap he didn't say if still using a single cam.
Old Dec 17, 2013 | 09:51 PM
ajbardo's Avatar
Ok I'm willing to learn something new. Please tell me why I didn't do it in 40 min? I just checked the head to make sure what I own because I didn't want to give false info. My car is a 98 ex with a d16y8
Old Dec 17, 2013 | 09:53 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
What makes it so much more difficult on the DOHC? I've only had the pleasure of SOHC tampering with so far.
Old Dec 17, 2013 | 10:31 PM
NotARaCist's Avatar
...I've done it more than once without any kind of special tool. The tool just keeps it from tightening the clearance while you're tightening the nut. It's an oiled assembly, so the torque values are extremely predictable - you can figure out how much it will tighten the tolerance while you torque down the nut, leave the clearance loose by roughly that amount, and then torque it down. Doing that, it should be roughly within spec.
Does the tool make it easier? Hell yes it does. Is it entirely 100% necessary? Nope.
Old Dec 17, 2013 | 10:46 PM
ajbardo's Avatar
I'm not driving a race car so I didn't need it to be within 2ip. The boxed end wrench way worked fine for me and that was 3rd miles ago.
Old Dec 18, 2013 | 05:04 AM
I have a spare b18c1 head lying around look at what I circled they're about an inch and a half down in the head no box wrench in there that's why I said it's extremely hard.
Old Dec 18, 2013 | 08:57 AM
ajbardo's Avatar
Ok, In that case you are correct. You can not do the valves without that tool. when talking about the head vald and I have, your wrong. On the d16y8 you can use a box end wrench and a flat head like we have been saying.
