D16z6 build. 97 civic.
Old Dec 12, 2013 | 12:09 PM
Jeremy911's Avatar
Default D16z6 build. 97 civic.
Im putting in a d16z6 in my 97 civic dx. Do i need any thang. I just have full motor and ill be using my dx trans. I need obd1,p28 ecu,i thing d16z6 wiring harness. Dont really know where to start on the build. I have a turbo manifold and cold air intake for it and thats it for now. Please help me if u have any ideas on what to do.
Old Dec 12, 2013 | 12:17 PM
kyden's Avatar
Default Re: D16z6 build. 97 civic.
swap out the transmission for an ex transmission.
Old Dec 12, 2013 | 12:33 PM
B_Swapped93's Avatar
boost it N/A on a d-series is pointless.
Old Dec 12, 2013 | 01:39 PM
dake7's Avatar
Short list:
-Yes get the d16z6 engine wiring harness
-Yes you will need the P28 ECU
- Also will need an OBD2 to OBD1 wiring adapter
Old Dec 12, 2013 | 02:32 PM
Jeremy911's Avatar
Thats what i was thinking on doing. What do you think i should do to the head to make it stronger.
Old Dec 12, 2013 | 02:49 PM
apexi_rsx's Avatar
nothing just save ur pennies and boost it. u are going to have to wire vtec into your dx harness its 3 wires and easy...
Old Dec 13, 2013 | 11:57 PM
Jeremy911's Avatar
Shouldent i get some up grades on my head after i boost it. I know there is somthing that fail on that motor arround 200hp.
Old Dec 14, 2013 | 12:05 AM
apexi_rsx's Avatar
I ran my car boosted stock block on a gt28r with 10psi which would be near 200hp for 5 years nothing broke til I spun a rod on an over due oil change. that stock head can make up to 300hp you are going no where near these limits so leave it alone u will be wasting your pennies
Old Dec 15, 2013 | 09:16 AM
Jeremy911's Avatar
What are some good pistions and rods that will be good but not that pricey.
Old Dec 15, 2013 | 09:23 AM
HondaPartsHero's Avatar
Technical Hero
Originally Posted by dake7
Short list:
No the Z6 harness will not work in your car. Follow this guide for OBD1 engine in OBD2 car.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-00-honda-engine-swap-wiring-guide-vtec-non-vtec-2987229/
For the rest search in the forced induction thread for builds on Z6's and copy a build that fits your power level and price range desired. Don't reinvent the wheel.
Old Dec 15, 2013 | 09:25 AM
just swap a b-series in before you even think of wasting money on a single cam, rods pistons....if you're asking what type you're not going to be installing them your self.
memorybox
Jul 4, 2006 10:06 AM
Amf_crx
Mar 20, 2004 02:52 PM
chrystyle
Feb 19, 2004 05:29 PM
