b18b1 starts than immediately dies
Old Dec 11, 2013 | 09:46 PM
peteyparado's Avatar
Default b18b1 starts than immediately dies
got a 94 eg with a b18b1 swapped. this swap was done years ago this setup was running fine till about a month ago, it started dying right after it starts.
i check timing fuel,fuel pressure,air,spark all check out. i would have to crank the motor till it starts.mayb a few minutes of trying till she go's. at first it would run fine for weeks than days.could it b the igniter? thanks
Old Dec 12, 2013 | 07:44 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: b18b1 starts than immediately dies
so you have proper fuel pressure?
pull back seat and do you hear the pump prime when key goes to ON?
pump runs when ingition is turned?
screen could be clogged?
clogged cat can also do it.
any CELs? check compression?
95Sedan
Nov 12, 2013 04:47 PM
got_no_sol
Other Make Vehicles
Nov 1, 2011 09:13 PM
dannycraq
Apr 2, 2008 08:55 AM
22boost
May 13, 2006 04:44 AM
baonest1
Aug 18, 2003 11:22 AM
