bad gas millage and loss of power on hills!Catalytic?
Old Dec 11, 2013 | 12:51 PM
DCcrx's Avatar
Default bad gas millage and loss of power on hills!Catalytic?
recently started getting poor gas millage and a loss of power on hills. hiway. cleane PVC, fast idle thing and changed plugs! idles better after i disconnected the fast idle thingie....plugged the hose. could the catalytic converter be getting clogged? or what next. thx
Old Dec 11, 2013 | 12:58 PM
4drEF's Avatar
Keyboard Humorist
Default Re: bad gas millage and loss of power on hills!Catalytic?
When's the last time you have done any regular maintenance to the engine?
What all was done?
Is the Check Engine Light lit up on your dash?
Old Dec 11, 2013 | 01:06 PM
DCcrx's Avatar
changed plugs, cleaned fast idle, new cap and rotor, cleaned with carb cleaner. about 2 months ago. one cold early morning i got on it to get on the freeway and me check engine light came on, so 16 flashes, fuel injectors. took it home reset, haz fuse, and never came back. been two weeks. been getting poor gas millage. use to do 100 mph no problem...calif. I80 flow of traffic! now its slow to get to 85. fuel injectors going bad? thx.
Old Dec 12, 2013 | 06:46 AM
DCcrx's Avatar
up date....while going home from work (50 miles) used 1/4 tank of gas!!! AND noticed the tail pipe was sooty black!! what controls the fuel mixture? so, to work and back i used 1/2 tank of gas! seems to be getting worst. where do i start replacing parts? thanks.
Old Dec 12, 2013 | 09:33 AM
Freemananana's Avatar
You probably have an injector that is clogged and stuck open causing you to use loads of gas. Most likely causing a misfire too, which would explain the loss of power. It is probably flooding the cylinder since it can't shut all the way. Is it the DPFI injectors? If so, now would be a great time to move onto MPFI.
Old Dec 12, 2013 | 09:45 AM
DCcrx's Avatar
thx, Bro.will go thru injectors. i Have the PGM-FI dual point. but am willing to switch over to the MPFI. whats required to do the change? dont mind spending the $ for my main commuter. great and loyal Hooptie! thanks again.will up date.
Old Dec 12, 2013 | 09:57 AM
Generally speaking:
Intake manifold (with injectors and throttle body)
D16A6 MPFI Distributor
ECU
Then it is just 4 additional wires. It's very simple, in the FAQ section. Will run you a couple hundred bucks most likely.
Old Dec 13, 2013 | 07:16 AM
DCcrx's Avatar
for now. is there any way to check injectors when i remove to inspect them. how much voltage to actuate the solenoid, do they come apart, ohms? best place to get new ones? I'm doing this because I'm in the middle of a 67 Chevelle project. thx. and Merry Christmas!
Old Dec 13, 2013 | 07:59 AM
Not really sure on how to test them. You can google how to clean them though. It's pretty intensive. I would just buy new ones.
Old Dec 13, 2013 | 08:40 AM
4drEF's Avatar
Keyboard Humorist
Your O2 probably should have been faulting like crazy.
I'm going to guess that it might be your problem - they get old and lazy.
Just enough to keeping working without throwing a fault and barely working enough to run properly.
Old Dec 14, 2013 | 07:09 AM
DCcrx's Avatar
thx 4deEF, never got a fault code, had it replaced for smog a year ago. but probably an after market crap! are there two? does that control fuel mixture? will try that too. exhaust always smelt rich!
Old Dec 16, 2013 | 02:35 AM
Our cars only have 1 O2 stock. I believe the Y8 has 2 O2 sensors.
Old Dec 16, 2013 | 07:44 AM
DCcrx's Avatar
Hey, thanks Guys! found the problem! i Pulled 1 of two fuel injectors and noticed the o-rings were all stretched out! wtf. bought a o-ring kit from OReily's about 6 months ago. cost about $70 bucks. i put the old ones in and wallah! gas save again! does anyone know exact size of these so i can get only the 2 rings per injector only maybe in viton? thanks for all your advice and experience.
Old Dec 16, 2013 | 08:17 AM
You want just the O-ring? Why not measure it. Or you can try and find it online.
http://www.hondaautomotiveparts.com/...E+BODY+%281%29
020-023 I believe are O-rings. Don't know which you need.
mlanning
Apr 20, 2015 05:44 PM
RacerRex
Sep 1, 2011 05:23 PM
weirdone86
Dec 8, 2006 07:20 AM
Insane Si Lum
Feb 8, 2006 02:14 PM
mymeatb18"
Feb 9, 2005 08:20 PM
