GSR in EJ1 question
Old Dec 10, 2013 | 08:33 PM
tico's Avatar
Default GSR in EJ1 question
what throttle cable bracket should be used for this setup. my motor did not come with one..
also what can i do about my radiator hose to radiator size differences. been looking for a half size radiator that fits b series hoses but to no availl
Old Dec 10, 2013 | 08:35 PM
slowhatchcali's Avatar
Gsr bracket with gsr cable
Old Dec 10, 2013 | 09:06 PM
tico's Avatar
Default Re: GSR in EJ1 question
sweet thanks. what about radiator outlet to hoses dilemma?
Old Dec 10, 2013 | 09:30 PM
For hoses you use the gsr hoses with your stock radiator. Just get the worm type clamps.
Old Dec 11, 2013 | 07:36 PM
dake7's Avatar
Stock GSR hoses
--> Use 94-97 Del Sol DOHC vtec Radiator.... you need the one with 1-1/4" inlet and outlet for the hoses to fit properly.... yes the stock civic rad with 1-1/8" fittings will work but it really squishes the hose and you risk having leaks....
Old Dec 11, 2013 | 08:25 PM
You can also use the 99-00 Si radiator to fit the diameter of the hoses.
MadCoder
Oct 17, 2013 04:58 AM
helpmycivic
27
Feb 24, 2007 11:51 PM
som3on3_10
Nov 30, 2004 01:52 PM
EGsex
Dec 22, 2002 09:49 PM
