ls/vtec build problems
Old Dec 10, 2013 | 04:36 AM
dc r-spec's Avatar
Default ls/vtec build problems
Finished my ls/vtec build. Running b18a block with b18c5 pistons. New honda piston rings and acl bearings. Has a stock b16a2 head with arp head studs. Can anyone tell me how bad these are supposed to smoke during ring break-in? or how long it is supposed to last?
Old Dec 11, 2013 | 07:11 PM
Eg.ls.turbo's Avatar
Default Re: ls/vtec build problems
Should only smoke for half a min or so. Any longer then u either didn't shave the rings to the correct specs or u have oil leaking to the pistons, could also b headgasket not torque right.
When I built mine it only smoke for like 20seconds then it cleared up.
Old Dec 12, 2013 | 03:17 AM
blackeg's Avatar
How many miles on the motor so far? Did u put some load on it right off the bat? U can always try a compression test keep in mind the numbers might be a bit low u sont have much carbon in the cyl yet but they should still be even.
Old Dec 13, 2013 | 12:07 PM
93egSLEEPER's Avatar
This may sound stupid, but did you use new rings and have a fresh hone done on the block? Also did you clock the rings?
Old Dec 18, 2013 | 05:06 PM
dc r-spec's Avatar
rings were clocked properly, block was freshly hones, rings gapped by the machine shop. went through the head bolt torque to ARP specs. Performed both a leak down and compression test. Numbers from the compression test are 210 across the board and the leakdown test showed 15% or less on a cold motor. Motor was run for approx. 20 mins at idle, fast idled at 2k rpms for 20 mins and shut down. Motor oil, filter and plugs were changed at that time.....
Old Dec 18, 2013 | 05:13 PM
Sounds like you may just need to take it out, run it hard and get it hot and clear out the holes and see where you stand. Are we talking white. blue or black smoke? Does it smell like fuel?
Old Dec 19, 2013 | 10:21 AM
halfakneegrow's Avatar
get it tuned.. it should clear up during the tune session is everything seated fine
osbunjosh
14
Apr 16, 2011 05:05 PM
tkewtn
Nov 2, 2007 12:13 AM
bOOsT-FeIn
Oct 17, 2006 06:53 PM
KingOfQB
10
Mar 4, 2006 07:30 AM
riceburnah
Apr 22, 2003 08:41 AM
