B18B1 civic HELP PLEASE
Old Dec 7, 2013 | 02:10 PM
B swapped civic's Avatar
Default B18B1 civic HELP PLEASE
Hello everyone, I'm kinda new to the whole civic and tuner scene but I bought a b18b1 with headers, intake and a greddy exhaust about a month ago.It has been running rich, getting about 20 MPG and I can smell gas when I'm idling at a stop. I checked spark plugs and they all looked good. Also if I don't let the car run for a few minutes before I take off the car will not rev pass 2500-3000 RPM and it feels like it's bogging down but it goes away after a little while. Also the car takes a long time to warm up in the cold weather, usually the temp gauge doesn't even move on my 8 mile drive to work. I was thinking replacing the thermostat would fix that but I wasn't sure. Any help would be greatly appreciated.
Old Dec 7, 2013 | 02:21 PM
b20bFourDoorCivicLX's Avatar
Default Re: B18B1 civic HELP PLEASE
engine doesnt belong in car...first of all....so a tune / dyno tune would help ALOT with MPG and Fuel Ratio and throttle response and such.
second i would check if you have a cel = check engine light.... and fix and go from there...
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
What year and model is the engine in? What ECU are you using? Are there any CELs(Check engine lights)? Does the CEL come on initially when you start the car then go off?
Old Dec 7, 2013 | 02:26 PM
it's in a 93 civic coupe, I'm not sure about the ECU but there are no check engine lights and it does come on at first
Old Dec 7, 2013 | 02:28 PM
Fliptard's Avatar
change thermostat, make sure u have correct ECU, check TPS voltage.
IF you arent sure what ecu you got. you are obviously not experienced with this kind of swap/car meaning you need help from someone who does or you will just give your self a head and waste money....
goodluck
Old Dec 7, 2013 | 02:29 PM
This may be a stupid question but I just want to make sure, since it is an integra engine I need a thermostat for that engine or would it be the same as the stock d series thermostat?
Old Dec 7, 2013 | 02:30 PM
Fliptard's Avatar
for an integra.
Old Dec 7, 2013 | 02:31 PM
Its a Integra engine bro you need a Integra thermostat,Spark plugs etc, As for Suspension SOME Parts are Interchangeable ....
Old Dec 7, 2013 | 02:39 PM
Thanks. Anyways, I just went outside and looked it's a p75 ecu. When I checked the TPS voltage it was good aswell
Old Dec 7, 2013 | 02:51 PM
try spark plug wires,spark plugs, fuel filter. oil filter etc start from there
Old Dec 7, 2013 | 02:54 PM
Fliptard's Avatar
you don't have any CEL's?
Old Dec 7, 2013 | 02:55 PM
So that is the correct ecu? I did spark plugs, the wires look good but new ones wouldn't hurt. I did an oil change when I got it and I'll do the fuel filter next weekend probably. Are there any other possibilities?
Old Dec 7, 2013 | 02:56 PM
It turns on for a second or two when the key is in the on position but not when the car is running
Old Dec 7, 2013 | 02:57 PM
Fliptard's Avatar
o2 sensor could be bad, and not throwing a code.
Old Dec 7, 2013 | 02:59 PM
Is there a way to test the o2 sensor without just throwing money at it?
Old Dec 7, 2013 | 03:03 PM
Fliptard's Avatar
http://www.preludepower.com/forums/s...d.php?t=268999
Old Dec 7, 2013 | 03:19 PM
Thank you very much
Old Dec 7, 2013 | 03:53 PM
dfanatic86's Avatar
I'm curious as how you checked the tps, did you back probe the senosr? And if so, what were your voltages at the closed and WOT positions?
Old Dec 7, 2013 | 04:09 PM
Yes I backprobed and checked it with an oscilloscope, although I do not remember what the voltage was, I tested it about 2 months ago
Old Dec 7, 2013 | 04:52 PM
Marvin1985's Avatar
Open the ecu and see if it's chipped
Old Dec 7, 2013 | 05:35 PM
alright I'll go check it tomorrow, it's cold and late haha. But what if it is chipped?
jdm.boi408
Jul 4, 2012 08:16 PM
zeplin
Jan 26, 2009 12:08 PM
freeagent314
Oct 8, 2008 08:02 AM
timmav91
Jun 28, 2007 10:49 AM
2gen_tegs_rule
12
Oct 14, 2006 06:14 PM
