Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Lossing power in Rain
Old Dec 7, 2013 | 08:26 AM
Hondagirl@03's Avatar
Default Lossing power in Rain
I have a 2003 Honda Accord Lx, lately it has the tendency to briefly loss power when it rains. It usually happen when I slow to turn. it doesn't stop completely, but the battery light comes on and the steering locks, then it goes back to normal. What can be causing this?
Old Dec 7, 2013 | 09:03 AM
ferio-ichi3's Avatar
Ferio Wdm Edition
Default Re: Lossing power in Rain
Sounds like a grounding issue. Check for loose grounds maybe?
Old Dec 7, 2013 | 10:09 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Sounds like an idle issue. Get a can of brake cleaner(or throttle body cleaner if you must) and clean out the throttle body.....
Old Dec 7, 2013 | 11:44 PM
Ferio Wdm Edition
Why would that be the issue? If his car shuts up in the rain, id look for grounds 1st. He isnt sucking in water or else he would hydrolock..unless im missing something else
Old Dec 8, 2013 | 06:02 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Its happening in the rain because it is cold and the carbon build up in the TB is much more dense. The vehicle is dying under a load when the rpms are low(driving slow).
When the rpms(and consequently,airflow) are low, it is the idle valves' job to keep the car running. But it cannot do its job if airflow is restricted. This is a common occurrence.
Of course Im just speculating on the interweb,could damn well be anything. But it takes all of 10-15 mins to clean out the TB and eliminate it as the fault.....
Old Dec 8, 2013 | 09:01 AM
Lost Again's Avatar
I'd agree on checking/doing both suggestions.
My question to the OP - are you running a stock/OE intake or do you have some aftermarket intake?
Old Dec 8, 2013 | 10:08 AM
Ferio Wdm Edition
Oh ok DC! I didnt know that, good stuff to know man.
turboda4dr
Jan 15, 2011 12:11 PM
Da9austinRacing
Feb 7, 2010 08:07 AM
a.nalazek
Aug 29, 2006 06:46 PM
notstock93
Sep 1, 2004 09:20 PM
VTC_CiViC
Oct 10, 2002 04:57 PM
