Custom B20B head gasket for turbo
Old Oct 27, 2002 | 10:19 PM
turbopanda's Avatar
Default Custom B20B head gasket for turbo
I had a custom head gasket made for my B20B - this one is 2mm thick, and will drop my C/R to about 8.5:1 with stock B20B pistons and rods
does it look okay, construction-wise? the shop I had it done at is the same shop that makes custom head gaskets for JUN Thailand. I used their headgaskets in my D16Y8 turbo too, seemed to hold up great. Never blown one up.
Old Oct 27, 2002 | 10:50 PM
rjardy's Avatar
Default Re: Custom B20B head gasket for turbo (turbopanda)
Yeah man that looks great. Worried about cracking them b20 sleves? he he
Rob
Old Oct 27, 2002 | 11:34 PM
turbopanda's Avatar
Default Re: Custom B20B head gasket for turbo (rjardy)
tHE word worried doesn't even begin to describe the amount of fear contained within me from boosting this engine on stock internals!
EDIT: typo
[Modified by turbopanda, 3:36 PM 10/28/2002]
Old Oct 28, 2002 | 01:28 AM
rjardy's Avatar
HE HE i hear that, but you will be okay, your not some dumb kid who doesnt know whats going on. Is this the car that has the LINK management? You have so many cars i lost track
Rob
Old Oct 28, 2002 | 02:56 AM
turbopanda's Avatar
Yes, its got the Link standalone ECU with an A/F Lambda meter and Knock meter. People here are saying that B20B engines are sensitive to detonation, so I guess i'll know about it first with the things I have, before something goes wrong. I hope..
Old Oct 28, 2002 | 03:09 AM
BoostedED9's Avatar
looks good.. i have a greddy 2mm on my d16z6 anyone know what it could have droped my compression to?? i did a test and the cylinder compression was 205 before and 175 after..
Old Oct 30, 2002 | 04:11 AM
BoostedED9's Avatar
Default Re: Custom B20B head gasket for turbo (ED9Hybrid)
anyone???
Old Oct 30, 2002 | 07:43 AM
avividmemory's Avatar
where did you have that made, and how much did it cost ya?
Old Oct 30, 2002 | 09:21 AM
MysteryWagon's Avatar
What camera is that? I can see germs on your fingers
Old Oct 30, 2002 | 11:59 AM
turbopanda's Avatar
Default Re: Custom B20B head gasket for turbo (SpoolinLS)
I got it made at a shop over here in Thailand. Top quality construction, custom-made, any thickness you desire for any engine.. whether it be a D or B series (or any other manufacturer for that matter).
Do I sense that people are having interest in purchasing head gaskets from me now?
Old Oct 30, 2002 | 01:35 PM
Sonny's Avatar
It should have dropped it from ~9.2:1 to ~8.5:1
Sonny
Old Oct 30, 2002 | 02:46 PM
Ri5e's Avatar
Even with 8.5:1 compression I still cracked my b20 sleeves
Old Oct 30, 2002 | 06:47 PM
turbopanda's Avatar
Default Re: Custom B20B head gasket for turbo (4 Stroke)
Were you running with a blockguard?
Old Oct 30, 2002 | 06:49 PM
Jared's Avatar
tuning
Old Oct 30, 2002 | 07:20 PM
Quick 200k Mile Motor's Avatar
People here are saying that B20B engines are sensitive to detonation.
..might be because of the mismatch of head chamber 81mm & cylinder 84mm. I still have this theory that any long stroke motor is "edgy" and sensitive to detonation.
Old Oct 30, 2002 | 09:11 PM
turbopanda's Avatar
Default Re: Custom B20B head gasket for turbo (Quick 200k Mile Motor)
*nathan feels very uncomfortable whenever he hears comments like this about turbocharging b20b engines..*
why do i regret buying this engine...
Old Oct 30, 2002 | 09:15 PM
dbman96's Avatar
New User
I hear ya - I'm running a B20B in my GSR ever since my 18C got destroyed and now I'm getting more and more nervous, but I figure with a standalone and decent tuning I should be OK, particularly since i'm not running any more than 8-9 psi. Does make me want to go out and double-check that my base timing is still setup correctly with the AEM ecu.
Old Oct 31, 2002 | 06:13 AM
POLLO's Avatar
Nathan should relax and take it easy , he boosed a D series like crazy every day when the D series sleeves are good up to 20 psi supposely and you took it waaay beyond that. you should not be worried of the b20
Old Oct 31, 2002 | 07:19 AM
Hayasa15's Avatar
Default Re: Custom B20B head gasket for turbo (POLLO)
what is the cost of your custom headgasket?
Old Nov 6, 2002 | 11:57 AM
turbopanda's Avatar
Default Re: Custom B20B head gasket for turbo (Hayasa15)
It was a *little* bit cheaper than a new cometic headgasket. I could make them for you guys if you wanted them, but once you add shipping costs, i'm sure you'd be better off just getting a cometic headgasket locally
Old Nov 6, 2002 | 12:02 PM
turbopanda's Avatar
My B18C head has already been matched to the 84mm cylinder in order to drop the compression even further.
BigDare23
Aug 11, 2009 05:22 AM
jdm_h22
Aug 30, 2008 08:06 PM
BILLY_BLING
Sep 28, 2006 04:44 PM
GapxGuy
Mar 7, 2003 11:58 PM
Mr. Vapor
Dec 22, 2002 04:43 PM
