Failed smog high numbers
So my friends 2000 Accord just failed smog. His numbers:
MAX MEAS
15 MPH HC- 56 119 (FAILED)
CO-.51 .56 (FAILED)
NO- 443 966 (FAILED)
25 MPH HC- 40 122 (FAILED)
CO- .49 .59 (FAILED)
NO- 730 565 (PASS)
Those numbers are pretty high. I'm leaning toward a new cat.
Just got a new o2 in recently, and changed oil, plugs, wires, cap and rotor, air filter, timing belt, water pump, coolant, and thermostat about 3000 miles or less ago.
Everything is stock. Don't remember what his mileage was but it was pretty high. Close to 200K.
Do you guys think i can maybe sea foam, adjust valve lash, and use Heet that we might be able to pass the car? Or should we just get a new cat?
Thanks for looking
MAX MEAS
CO-.51 .56 (FAILED)
NO- 730 565 (PASS)
Thanks for looking
its check and worth a shot!
they will refund ur $$ if u fail after using it.
MAX MEAS
CO-.51 .56 (FAILED)
NO- 730 565 (PASS)
MAX MEAS
CO-.51 .56 (FAILED)
NO- 730 565 (PASS)
At 200K if the EGR ports have never been cleaned they are probably gummed up a good deal, this would cause a lean misfire which will indicate both a lean and rich issue as well as an increase in NOx emissions. Purchase a new EGR valve gasket, and a upper intake plenum gasket. To clean the EGR ports on a F23...
Originally Posted by 92civlude
The F23 does not have an access plate or EGR plugs on the runners. The plunum has to be removed. With the upper plenum removed, as youre looking at the engine, the egr port is on the left side of the lower intake. Clean it out with carb cleaner. Clean the upper plenum as well.
From RockAuto the gaskets would cost ~$5+shipping.
Have there been any misfire(P030*), catalyst below threshold(P0420), or insufficient EGR flow(P0401) codes? Does the car have a slight stumble or hesitation while at cruise RPM? Just because a code is not set or saved does not mean there is not a problem with a system
Make sure the CEL light does indeed work. Here in Calif the smog techs should be checking for the CEL and or any active codes, but sometimes they are lazy.
If any tuneup work was done right before going for the smog test, this will skew the test numbers as a new ignition system will burn hotter and burn off some of the carbon deposits in the combustion chamber. This will elevate emissions output as the deposits are removed.
What brand of O2 was used? Only use Denso or NTK.
You may have an exhaust leak. You should check that. You can use seafoam to find an exhaust leak. You will see white smoking coming out of the exhaust anywhere from the exhaust manifold to the oxygen sensor. Look carefully there as you seafoam.
Did a cat work for you? Im kinda in the same boat... Except with my del sol. Its gotta b16a3. Except here in washington we test at cruise (2500 rpm) then at idle. the curise was fine, i was at 348 HC (PPM) max allowable limit was 400. at idle though it shot up to 1042!!? any ideas? P.S the resonator has about a finger size hole in it.. lol
spermdoggy
May 25, 2012 06:20 AM
reyrey2006
14
Feb 4, 2012 12:11 PM
dem0nk1d
Jul 7, 2006 11:11 AM
