Car will drive fine then not restart, or stall and restart, or not, very strange...
Old Dec 4, 2013 | 06:19 AM
nitro169's Avatar
Default Car will drive fine then not restart, or stall and restart, or not, very strange...
I have a 94 civic DX automatic that will stall completely and not restart.
The car will run fine and then just fail, all lights remain on, just losing ignition or fuel or both.
Afterwards it will sometimes start right up, or sometimes when I turn the key to the on position the fuel pump will not kick in, the engine light will stay on and flicker with a sad random clicking from the solenoid in the shifter.
After some retrying or after waiting a while you can turn the key and hear the fuel pump kick in, and the shifter solenoid doesn't make any noise and the car will start fine.
Does anyone have any ideas what this is caused from???
I have replaced the relay and the fuel pump, almost seems like an electrical short, like the relay is trying to activate the solenoid in the shifter instead of the fuel pump.
Any ideas before I go throwing more money without knowing where to throw it would be greatly appreciated.
Thank you
Old Dec 4, 2013 | 06:31 AM
Former User's Avatar
Default Re: Car will drive fine then not restart, or stall and restart, or not, very strange.
Might be abad ECU, but start by cleaning and tightening the G101 ground on the thermostat housing. What's needed are some electrical tests of the main relay circuit when the engine will not start.
Old Dec 9, 2013 | 05:00 AM
nitro169's Avatar
Is there anywhere you can direct me to an electrical check tutorial?
l3adunkadunk
Feb 1, 2010 05:53 PM
GSR_Hatch8
Jun 17, 2009 05:27 PM
Jooleeus
13
Jul 20, 2008 08:46 AM
LigerZeroWPC
Oct 3, 2006 09:05 AM
H22CL
Aug 1, 2005 05:43 AM
