Car will not go over 40mph after replacing timing belt
Old Dec 4, 2013 | 12:08 AM
ekdriver707's Avatar
Default Car will not go over 40mph after replacing timing belt
So my timing was off by 2 teeth but drove fine. I slipped off the belt but couldn't line it back up. Found out there was no crank key to keep the crank pulley from spinning when I tried to take it off with my electric power tool(crappy tool). I spun the cam shaft pulley around like 10 times with no belt attached. Timing was way off every time it started the car. It sounded like a motorcycle and idled like crap. So I just took everything off and bought new replacement parts and redid the timing. I lined up everything and it started just fine, idles just fine, but when I go and drive it. The car doesn't want to go over 40mph and feels like it has no power. Could I have bent a valve? Or messed up some rings so I have bad compression? This is over my head
Old Dec 4, 2013 | 01:05 AM
frost_white_ej1's Avatar
who know it could be anything why not do a compression, and a leak down test before asking for help if one or both test show negative try adjusting the timing again, if it show positive then pull the head off and inspect for damage, just because you have all the marking align doesn't mean it in the correct timing position! did you use a timing gun and did you take off the distributor when you replace the part if so did you re-adjust the distributor to be in the correct position? alot of thing come into play and the only way to find out is to diagnose it one step at a time.
Old Dec 4, 2013 | 01:34 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Car will not go over 40mph after replacing timing belt
Compression test and post the numbers
Old Dec 4, 2013 | 05:01 AM
B_Swapped93's Avatar
just spinning the engine by hand(even air tools) shouldn't bend valves even if it's off by a lot I've done it many a time. but as said comp test and see what's up.
Ef4doorwagon
17
Aug 30, 2014 11:58 PM
aznflipboi08
Dec 27, 2009 11:24 PM
ampm
12
May 3, 2007 10:53 PM
ek_chris
Nov 8, 2006 07:26 PM
AlexT
Sep 28, 2004 06:07 AM
