Smog Gurus ... Needing Your Help
Old Dec 3, 2013 | 02:19 PM
germanturtle's Avatar
Default Smog Gurus ... Needing Your Help
95 eg with obd1 gsr swap - bard/refd in cali needs advice on smog
got the notice in the mail - removed all the go fast parts that dont have carb numbers on them. installed oem cat, oem exhaust, oem exhaust manifold, virgin p72, oem intake arm and box. took her to have a go at smog - first time since the nightmare of the ref process....failed of course, dammm.. heres the numbers
first try
----------------co2-------o2---------hc-----------co--------no
15mph ---------14.--------.6 ---------25---------.01------- 2841-------fail
25mph ---------14.5--------.1---------14---------.00---------677------pass
second try
---------------14.1--------.0----------13----------.05-------2360-------fail
----------------14.0-------.3-----------6----------.14--------126-------pass
max allowable #s
15mph 92 .55 716
25mph 57 .54 764
so went home scratched head and dug in.. checked and adjusted timing to dead on, inspected and replaced the spark plugs, removed ALL gasoline in tank,added royal purple fuel system additive, replaced gas with 91 octane chevron- which is what i run daily! cleaned junk off fuel filter.removed and replaced air filter and had another go at smog. this time i drove the car for 35 minutes off freeway speeds or higher to get the cat as hot as possible - im running all oem heatshields on header and cat fyi. pulled in to smogged and smogged it - failed again! both times i passed all visuals, gas cap test, timing check, and whatever the hell he clamped off with needlenose pliers. so basically i am passing everything but the no at 15mph.
i did a seafoam treatment - yeah i know some say yeah its good others disagree. i already did it so i dont want to start a rant on how i shouldnt have blahblahblah... removed and replaced the o2 sensor. now what?? so here's a little review for the people that scan through stuff -
new
o2 sensor
spark plugs gaped at 52
new cat
new air filter
new tranny fluid
coolant has been recently flushed and filled
drain and filled gas tank with 91
oem airbox, cat, headers
fuel system treatment in gas
seafoam through vacuum technique
any other things you can suggest i do before bringing it back for another go?
came home, scratched head a little harder and tried again to figure out what the hell it could be. forgot to mention that my lost motion assemblies are a bit noisy - not sure if that can affect emissions in a negative fashion.thanks for all your help - you guys came through major last time i had this smog episode!
Old Dec 3, 2013 | 02:28 PM
Default Re: Smog Gurus ... Needing Your Help
forgot i replaced the distributor with a new oem unit as well
Old Dec 3, 2013 | 02:51 PM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Post a picture of the sheet they gave you
Old Dec 3, 2013 | 03:04 PM
Marvin1985's Avatar
Valve lash in spec?
Old Dec 3, 2013 | 05:36 PM
i had the valves adjusted a few years ago so im not sure if there within spec still. i do know the lost motion assemblies tick like a pissed off typewriter.. ill post up sheets asap.
Old Dec 3, 2013 | 05:51 PM
the test that reflects an improvement is the second try
Old Dec 4, 2013 | 05:50 AM
bump for help..
Old Dec 4, 2013 | 01:05 PM
Former User's Avatar
Seems to be running lean - measure the fuel pressure and test the FPR.
Old Dec 4, 2013 | 02:00 PM
93egSLEEPER's Avatar
I love how they put GROSS POLLUTER in big bold letters haha.
I dont know if you have the ability to get it, BUT I couldn't pass emission a few years back w/ my built GSR. 1:1 mix ratio of premium unleaded to methanol got me zeros.
Old Dec 5, 2013 | 08:55 AM
thanks ron ill give it a go. running stock fpr and pump fyi
and to 93eg i know its nice GROSSSSSS POLLUUUTTTERRRR
Old Dec 5, 2013 | 09:08 AM
EpHatchy's Avatar
drop your timing to 14 degrees for the emission test should lower nox a lot.
im in the same boat as you only I failed both for nox. I changed out my 02 sensor cause my old one was fouled and my timing was not at 14 like I thought I had set it. goin to go back Friday.
lambda calculator indicates your a/f ratio is 14.75 :1 so your not running lean.cat might need a longer heat up session or your 02 sensor is lazy.
Old Dec 5, 2013 | 02:37 PM
video_voide's Avatar
NO is unburned fuel. The CAT's job is to burn it up.
Also check the ECT sensor, it sends the coolant temp to the ECU. Using a multimeter, test the sensor with the engine cold. Bring to operating temps and check again.
Old Dec 5, 2013 | 04:59 PM
canadaek's Avatar
No is nitrogen oxide it's caused by high cyl temp and usually controlled by the egr and converter ,, common cause's advanced ign timing,carbon deposits (high compression) lean air/fuel mixture. Hc hydrocarbons are unburned fuel . Co carbon monoxide is incomplete combustion
is you converter 50 state legal ? and is it a 2 way or 3 way ? carb legal converters are usually at least double the $$ of 49 state version
Old Dec 5, 2013 | 05:00 PM
tested fuel pressure today. vacuum line on pressure held at 38 maybe 39 without vacuum line attached pressure held at 48 to 49. since it was in spec i figure the pressure regulator is functioning properly. i thought long and hard and realised i have never changed my fuel filter id assume 5 plus years so i said wth and installed a new one today.thanks for the input fellas.. im thinkin tomoro ill pull the valve cover and check lash make sure it is within spec.
Old Dec 5, 2013 | 05:10 PM
sorry forgot to answer all questions, yes the cat is legal. i purchased it brand new from the acura dealership for the same year gsr to have absolute confidence it would pass every dam inspection possible. it has the serial number from honda and an oem heatshield in place. heres a quick review for whats done so far
new cat -less than 1000 miles on it
new o2 sensor- o miles
emptied/filled gas tank w chevron 91
seafoam treatment through vacuum line
oil/filter change
new air filter
oem exhaust mani
2 1/2" crush can b pipe with oem style muffler
oem intake box and arm
skunk2 intake mani with carb sticker
cleaned crud off injectors
untouched p72 ecu
Old Dec 5, 2013 | 05:11 PM
aem hi volume fuel rail..
Old Dec 6, 2013 | 12:11 PM
did a valve adjustment today.. anyone else got any input
Old Dec 6, 2013 | 01:13 PM
EpHatchy's Avatar
retard your timing.
Old Dec 6, 2013 | 03:57 PM
also got a new pcv valve today, looking for a gallon of meth as i heard it helps..
valve adjustment went fine and sounds a lot less angry.dropped in a bottle of lucas no reducing product. wth it cant hurt anything at this point. in regards to the statement someone made about my ect sensor... i did not test it yet but my temp gauge in the car has always functioned properly since i bought it. newer thermostat, running race radiator dual core, new coolant, watterwetter.
Old Dec 6, 2013 | 05:27 PM
timing is as low as it can go without failing the smog techs timing inspection . bump... any ideas people getting ready to try again, wanna cover all bases
Old Dec 10, 2013 | 08:03 AM
EpHatchy's Avatar
timing is 16 degrees + or - 2 degrees. on your sheet at the top is states your car is at 16. drop it back to 14.it will drop combustion temps and cool your nox readings.
rhymeshark916
Northern California (Sales)
May 28, 2011 11:28 PM
b18c1del
Jan 24, 2009 04:20 AM
integmester
49
Dec 11, 2005 10:51 PM
Rory Breaker
Sep 18, 2002 09:08 PM
infinkc
Jan 1, 2002 01:43 PM
