Seafoam=bad acceleration?
Old Dec 3, 2013 | 02:12 PM
bcintron95's Avatar
Default Seafoam=bad acceleration?
so just did the seafoam and now for some reason my acceleration is crap (only got to 60 on roads that i could reach 80 easily). so could it be the spark plugs? or would it be something else?
used half a bottle thru the vacuum line, and the engine didn't seize up. It sat for about 10 mins and then let the smoke clear out and drove it.
95 honda accord 122k miles 4cly auto
thanks in advance!
Old Dec 3, 2013 | 05:22 PM
lazlong's Avatar
Default Re: Seafoam=bad acceleration?
Could be plugs, what do they look like? Or some of that carbon you loosened got caught up in something (chewed a bearing, etc.) Or the loss of the carbon buildup exposed leaky seals, etc. Can you get any trouble codes out of it? http://check-engine-light-codes.blog...retrieval.html
Old Dec 3, 2013 | 06:39 PM
bcintron95's Avatar
nah no code or anything, plugs looked good too
Old Dec 3, 2013 | 06:50 PM
lazlong's Avatar
Try a compression test. Then a leakdown if there's loss of compression.
2 great vids:
Old Dec 3, 2013 | 08:16 PM
mrj_accord's Avatar
uuuummmmmmmmm.............
did u put back the hose?
Old Dec 3, 2013 | 08:36 PM
NZXTInerTia's Avatar
The vacuum hose? That wouldn't effect his acceleration. Obviously you need to do an inspection of all the parts in the "power" line of the engine. Spark plugs first.
Old Dec 3, 2013 | 08:38 PM
10psiLsEf2's Avatar
Could have burned ( melted your catalytic converter)
Old Dec 3, 2013 | 10:13 PM
holmesnmanny's Avatar
It may have finally taken out your oxygen sensor that was already on its way out.
Old Dec 4, 2013 | 06:07 AM
bcintron95's Avatar
well before doing the seafoam i put my stock air box back in but i didnt have the screws to keep it locked down, So i though that was the problem and put my sri back in. Seems to be running back to normal. thanks for the info guys.
h22nate
Apr 20, 2010 05:57 PM
EJ8_Enthusiast
10
Sep 28, 2008 07:29 PM
devnull
Aug 22, 2007 10:19 AM
boosted ek
Mar 30, 2005 11:34 PM
pip9
Aug 18, 2004 02:38 PM
