mystery oil leak seems too be oil breather box
Old Dec 3, 2013 | 10:41 AM
dupes4lyfe's Avatar
Default mystery oil leak seems too be oil breather box
I took a look at it and it seems to be the breather box ?? I have the exhaust bracket im taking off i got the buttom bolt off is there anything else i should be aware off for a d16y7?
Ps also my new breather box is plastic the one in this picture is a metal type thats rusted??.
Old Dec 5, 2013 | 08:12 PM
maksmizer's Avatar
Default Re: mystery oil leak seems too be oil breather box
check cv boot just incase, more common
Old Dec 5, 2013 | 09:56 PM
B_Swapped93's Avatar
the pcv box can be known to leak however I suggest spraying bpc around there and confirming it's the pcv box.
Old Dec 9, 2013 | 08:30 AM
dupes4lyfe's Avatar
Hello all thank you i got it done actually by removing the whole air intake manifold. It was the oil chamber had the tiniest rust hole causing drips after i filled it. Got the new one going on now.. one hell of a job antiseizing everything with new belts siliconing the tubes with new clamps should never be so hard for anyone else now.
letam06
Aug 16, 2013 03:35 PM
avotegra
Sep 4, 2008 09:43 AM
dubnine
Sep 6, 2002 05:22 PM
