Power windows and door lock issues
I've researched and found info on both the door lock and power window(s) isues I'm having. Just hoping to get responses to confirm my approach towards the forth coming repairs.
Door Locks:
1. Keyless remote stop working 6 months ago. replaced battery and tried resetting but unsuccessful.
2. Manual key lock stopped working a week ago. Cannot hear accuators working,. Fuse checked out okay. I haven't performed a continuity or other test described in the manual yet. However, seems to boil down to three possibilities. A) Accuator B) Control Module (relay) C) A break in a wire.. most likely a ground wire.
Power windows:
1. Driver's side is intermittent, but usually works the first time. Paasenger can be lowered with driver's side switch, but can only be raised using passenger side switch. I lubed both window tracts and moving parts inside the door.
2. I believe the driver's side control contacts are going bad and the choice is tear apart and resolder or replace with a salvage yard part.
Am I on the right track?
Door Locks:
Power windows:
bpenner
Honda Civic (2001 - 2005)
Jun 25, 2018 03:53 PM
adamk387
May 19, 2013 06:14 PM
ken00si
May 12, 2009 04:47 PM
gribbs
Apr 11, 2003 04:52 AM
Back in Black
Jul 7, 2002 12:27 PM
