! ! ! need help ! ! !
Old Dec 1, 2013 | 02:04 AM
BIG-T-GSR's Avatar
Icon2 ! ! ! need help ! ! !
So i'm putting back together my b18c1 I'm putting a new head gasket in it got all the cam caps and bolts on it torque all of them but 1 of the 6mm bolts snpped off I had the torque wrench set at 7.2 fp's it never clicked like it did on the other ones so i get 1 from a spare head got the broken 1 out started to torque it down again in the same thing was happening it seems like its going to break again i've turned it 2 more turns than the other ones still no click
Old Dec 1, 2013 | 07:04 AM
blackeg's Avatar
Default Re: ! ! ! need help ! ! !
ah i wouldnt worry too much about it its just the little bolt.i think those bolts are more for keeping oil from leaking out but if you used rtv/hondabond i dont think it would be horrible leaks. if you really are feelin like fixing it, i would unbolt the caps and take the cams back out. either chase the threads with a specific chase not a tap. if that doesnt help then i recommend a helicoil or other thread repair kit. this kind of stuff happens pretty often on old aluminum parts im sure you will use the helicoil again if you buy it
Old Dec 1, 2013 | 08:05 AM
AllMtrRex's Avatar
More than likely, the culprit to snapping bolts off at such a low tq number is.....a cheap torque wrench. Typically they are out of spec on just faulty in general.
TunerKid4lyf
25
Jul 12, 2013 08:01 AM
midnitesol
Apr 22, 2007 12:08 PM
CivicK20
Nov 11, 2006 06:03 PM
DOHClessEF-9
Dec 30, 2004 02:29 PM
xXx Justin xXx
Apr 1, 2004 07:20 PM
