D15b vtec block with y7 head?
Old Nov 29, 2013 | 04:32 PM
Chris0619's Avatar
Default D15b vtec block with y7 head?
I have a 99 ex with a D16Y8 that's tired. I think the rings are bad as it eats a lot of oil. I want to rebuild it but I need my car as it's my DD. I am thinking of a basic swap right now to keep it on the road while I do a rebuild of the y8. I can acquire a d15b vtec block, a y7 head and an auto y8 complete intake manifold with tb(for not much $$). Will that combo work? And which ECU would I need to run? The y7 ECU? Or use the stock ex ECU? This wouldn't be a long term solution, just until the y8 is rebuilt. Then I could turn and sell off that motor. Thanks for your help.
Old Dec 1, 2013 | 04:15 PM
Chris0619's Avatar
Default Re: D15b vtec block with y7 head?
Would this setup work? Where would I set timing? Normal? Or 4.5* out? Would I use the y7 ECU and the y7 injectors/fuel rail?
raider1qaz
11
Mar 2, 2014 04:14 AM
Hondalover15
Dec 5, 2012 10:13 AM
The Collin
Feb 26, 2007 03:59 PM
EJ8 944
10
Jan 27, 2007 03:51 PM
