h22a4 swap into 91 db1
Old Nov 28, 2013 | 10:51 AM
SuperDan222's Avatar
Default h22a4 swap into 91 db1
Hey so i got a 1991 teg gs model trim is db1, currently it has the b18a1 in there but i found a h22a4 from a lude, the lude is probably a 2001 not sure, i can get the full swap for $900. Engine trans ecu harness ect all included! How easy is this swap going to be? I have looked all over hondatech but cant find anything for my specific swap. Can i just use the ecu and wiring harness from the lude and drop it all in there? I am not using the car for anything right now so i have alot of time for this swap.
Old Nov 28, 2013 | 12:03 PM
fcm's Avatar
fcm
Old Fart
Default Re: h22a4 swap into 91 db1
It will not be a "plug and play", you will use the engine harness and the ECU/ECM, but mods will be needed for plugging in the engine harness to the Integra harness the same goes for the ECU/ECM.
BTW will be driving to the Peg on Sat. the 7th, how is the weather in Winterpeg? 94
Old Nov 28, 2013 | 03:55 PM
Sounds like something ive never done before :/ do you have any tips or pointers for me? Ill check online again specifically for this!
The weather is slippery but not too bad, i drive an awd subaru legacy to work so im good :D the forecast says -13 celsius cloudy maybe snow, riggt now we have about 20cm of snow
Old Nov 28, 2013 | 04:38 PM
fcm's Avatar
fcm
Old Fart
-13 C, not too bad and only 20cm of snow, that's not bad at all, I am renting a FWD car, [not going to try and drive my 89 Chry Dynasty winter car] and my 94RS is already tucked away for the winter, I did live in Winnipeg for 30 years so I am not that worried.
I am actually going to Portage la Prairie to do some custom wiring on a hot rod, replacing the complete harness and doing a wire tuck, but I have family in WPG so will spend the nights there.
I am pretty sure you will find the motor mounts you need and adapter harness, [jumper] you need for the ECU/ECM, you will also have to convert to a hydro clutch system for the transmission, but kits for that should not be a problem to find. 94
Old Nov 28, 2013 | 08:35 PM
G
Old Nov 28, 2013 | 08:39 PM
Found some good mounts on ebay. Thx for the pointer! However i could not find anything anywhere for hydro clutch systems.
As far as wiring harness jumper, are we talking about a obd2 to obd1 jumper here and if so how do i know which one is right? Obd2a or obd2b?? I get confused easily when it comes to ecus and stuff like that! Lol
Old Nov 29, 2013 | 07:06 AM
So if i got the entire clutch system from that prelude and put it in my teg that would be a hydro clutcch then woyldnt it be? The only problem would then be the differnece in length from clutch pedal to trans right?!
Old Nov 29, 2013 | 08:37 AM
fcm's Avatar
fcm
Old Fart
http://www.jdmhondaswap.com/contents/en-us/d701.html 94
Old Nov 29, 2013 | 09:17 AM
3rdtimecharmer's Avatar
10 Year Member
search for F2B/H2b discussion thread
Old Nov 29, 2013 | 09:56 AM
snobordboy's Avatar
Moderator
H2b might fit better, but sounds like the full swap might be more cost effective.
Check out explicitspeed for their mounts and conversion parts for the hydro clutch.
I would double check that the engine is not from an SH model, with the big ATTS unit on the back of the block, as the system would be useless weight in another car, and way to much of a pain to make work in a non-SH equipped car.
Old Nov 29, 2013 | 01:41 PM
Cool! Hey thx guys this really really helps ALOT! And i checked and it doesn't have alot in the back of the block, looks good. But thanks for the heads up! Found a cable to hydro conversion bracket for 165 shipped that I'll prob order, but as stated im not in a rush, actually have to fix my moms POS sunfire. That thing is a waste of time big time!!
Old Nov 30, 2013 | 03:11 PM
g
Old Nov 30, 2013 | 03:18 PM
ok so here is what i found:
http://www.ebay.ca/itm/331031058304?...84.m1423.l2649
btw do you have any recomends as to which mounts hardness i should use?? eg 75 85 95? as much as ive heard people say 85 but i want to know what you guys think!
also the engine doesnt come with a exhaust header and downpipe so i found this:
http://www.ebay.ca/itm/Prelude-H22-H...vxp=mtr&_uhb=1
i dont know anything about fdastwayracer...
still looking into the harness jumper situation... getting there
Torleif
10
Aug 20, 2015 05:29 AM
therest
Nov 13, 2012 03:41 AM
legend99
11
Apr 3, 2012 04:47 AM
heunde
10
Apr 10, 2008 12:32 AM
1SlowB16EF
Aug 3, 2005 04:08 PM
