replacing clutch over holiday, no clutch alignment tool
Old Nov 28, 2013 | 04:20 AM
turbo510_4_98's Avatar
Default replacing clutch over holiday, no clutch alignment tool
Title says it all, I ordered a new clutch online because mine is slipping like a ****, said it was supposed to have alignment tool but doesnt.
anyone know anything that would prove a reasonable substitute? Ill be replacing it either today or tomorrow so need something quickly if possible.
Old Nov 28, 2013 | 04:33 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: replacing clutch over holiday, no clutch alignment tool
What type of clutch is it?
Old Nov 28, 2013 | 05:13 AM
Sorry, this is on my 94 civic ex, d16z6, just a factory replacement
Old Nov 28, 2013 | 05:35 AM
instrument's Avatar
whos resurfacing your flywheel? or did you get a new one?
im sure if you post in a local thread someone will loan you one.
Old Nov 28, 2013 | 05:39 AM
LSTurbo23's Avatar
check your local autozones or parts stores...i had the same exact issue...went to an autozone and they had it..
Old Nov 28, 2013 | 05:56 AM
10psiLsEf2's Avatar
Honda,autozone,harbor freight.
Old Nov 28, 2013 | 06:17 AM
jdmh22eg2's Avatar
i have done MANY times with a very close sized socket to align or even my finger and leave pressure plate tad loose, slide trans on and then pull off trans tighten down.
Old Nov 28, 2013 | 10:42 AM
Ive tried all local parts stores, none of them can evem order it, ill check with honda tomorrow but dont wanna pay $30 from a dealer for a piece of plastic ill use once. Like the socket idea tho, thanks for the ideas guys.
Old Nov 29, 2013 | 03:49 AM
apexi_rsx's Avatar
advanced auto parts sells a universal clutch tool that's like a tapered cone and different attachments that will work with any transmission..... harbor freight has them for 10 bux and u will never need that plastic tool int he box again. ive used these before and they work perfectly. advanced wants almost 30 bux for thiers... I don't know how much mechanic work u do but if u do a lot like me its worth having... pic of tool here:
http://www.harborfreight.com/clutch-...set-66539.html
Old Nov 29, 2013 | 04:32 AM
Black R's Avatar
25 Year Member
Use a deepwell socket.
I've done it many times.
Old Nov 29, 2013 | 09:08 AM
I checked harbor freights website earlier and couldn't find anything, but that isn't too bad, im about to start pulling the transmission so if the socket idea doesn't work ill hop over to HF and pick that up. Thanks!
Old Nov 29, 2013 | 09:42 AM
k_than's Avatar
just like jdmh22eg2 states in his reply
use socket or finger to get aligned as close as possible with pressure plate a little bit loose to where clutch disc can still be moved around a little bit.put transmission back once transmission is on you can actually tighten the pressure plate inside the starter hole rotating the crank to get to the next bolt.
did this and it worked for me
Old Nov 29, 2013 | 10:07 AM
StreetRacinThug's Avatar
If actually centered some before with a socket and have had no problems what so ever.
Old Dec 1, 2013 | 10:56 AM
94EG8's Avatar
Seagull Management
Deep 10mm socket with a 6" extension, wrap the part of the socket that goes through the splines in the clutch disc with electrical tape to make it the correct diameter. If you don't have a socket that fits get a piece of wooden dowel, or anything really that fits pretty snugly in the pilot bearing, then build up the the part that goes through the clutch disc with tape.
Old Dec 1, 2013 | 01:11 PM
frost_white_ej1's Avatar
lolz with all the tool, it be nice to have an alignment tool much easier but not necessary, i done it many time just using my finger just don't tighten the pressure plate bolts make sure the clutch is center then torque the pressure plate to spec.
The_Honda_Guy
Mar 29, 2009 05:14 AM
philkehn
18
Aug 22, 2008 01:10 PM
janz3n
Oct 22, 2007 06:35 PM
onyx00
Mar 19, 2004 09:10 PM
