1993 Honda Civic Si Stuttering Problem
Old Nov 26, 2013 | 11:02 PM
Earthworm Jim's Avatar
Default 1993 Honda Civic Si Stuttering Problem
I googled and researched so before I ask, I'm going to state that I'm checking the distributor this week.
Briefly, check engine light, code said bad O2 sensor, also I had an exhaust leak in my manifold. My car sat for four days, fixed the O2, and the leak. While driving, around 75 mph, my car stars stuttering and suddenly dropping in speed. I swapped the speed sensor, cleaned the IACV, swapped distributor wire, checked for vacuum leaks, and cleaned basically every filter. My car is still stutter around 3,000 rpm (regardless of speed) and suddenly shuts off. The batteries cool. So uhhhh, any thoughts?
Old Nov 27, 2013 | 09:07 AM
Default Re: 1993 Honda Civic Si Stuttering Problem
Bump.
Old Nov 27, 2013 | 09:58 AM
93egSLEEPER's Avatar
Plugs and wires??
For it to stutter at that RPM like you made it sound it's either losing spark or fuel. Could have a relay starting to go out as well.
Old Nov 27, 2013 | 06:41 PM
Originally Posted by 93egSLEEPER
Plugs and wires??
I'll replace the spark plugs for fun, I also will change out some distributor stuff.
Old Dec 2, 2013 | 01:59 PM
Anything ever come of this?
Old Dec 2, 2013 | 03:38 PM
carlos8's Avatar
Stutter and randomly shut off, Check your ICM and coil.
h_civ2000
35
Oct 20, 2009 04:15 PM
axionm1k
Apr 2, 2008 06:58 AM
92BlackSi
14
Apr 8, 2005 11:00 AM
civictunr_ls
Feb 23, 2005 03:19 AM
integra*RS*
Nov 14, 2002 10:58 PM
